Results 1 to 6 of 6
    Senior Member Two Rings collegedude10's Avatar
    Jan 06 2008
    A5 3.2 6MT, B6 A4 3.0
    sunroof stuck, tilted sideways a bit...
    ok so i go to oepn my sunroof, it moves a little then stops. i try to close it, it budges a bit and then nothing! it seems like the sunroof glass is tilted sideways! youtube video is loading, will post when done. its about to rain outside too! grrrrr
    EDIT: ok heres the youtube video so you can see what im talking about.
    http://www.youtube.com/watch?v=W3lMaD-yzoQ
    2009 Audi A5 3.2 6MT
    hopefully this list grows...
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Re: sunroof stuck, tilted sideways a bit...
    have you tried the manuel crank.... should be inbetween the sunroof and the window... under the plastic panel where your light is.
    J Hope that helps
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Jan 06 2008
    in between the sunroof and the window? umm a little lost. is there a DIY for this?
    Senior Member Two Rings Sammy7's Avatar
    May 03 2008
    2003 A4 Avant, 1985 320i Baur
    San Angelo, TX
    Between the sunroof and windshield, where the switch/map lights are. I believe the DIY is in the owner's manual.
    Jan 06 2008
    forget it, found the hex key. want to here something funny? the hex key stripped the hex socket and now it just spins freely in there. ARGHHHHHHHH
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    looks like you're off the track some how. can you gently slide it into place?
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
