Results 1 to 12 of 12
    Dec 05 2007
    Turbo Talk Pt. 2
    Ok, this is a sequal to the last Turbo talk thread.
    I was wondering about the GT2876r yesterday. After reading that nicely placed together displacement thread by Crazyass (backwards), I did not know that to make the 06A block into a 2.0 liter all that would be needed was an MK4 crankshaft. No machining. As a noob, I know there will be other tads and bits to come along not mentioned, but at least it is not an extra (close to) a grand to get that extra .1 displacement for you 058 guys. At first, my plan was to just do rods and piston swap to run a bigger turbo. But after that thread, my mind changed.
    So, back to that GT2876r. I am a noob when it comes to this stuff, but I learn (have to say thanks to all on this forum board for that). If a GT30r with a built motor on rods and pistons can get you close to 400whp, can a 2.0 liter engine with the GT2876r do the same thing? Or close to 375whp? Plus no new front end with paint job will be needed. Then side skirts and rear end to complimment it. That is ~$1000+ that just welcomed itself.
    I just want some input to know what to research and which direction to head in. This of course will not be done for over a year from now, but it is good for me to get an idea of what to search for. Thanks in advance!
    *the more posts (info) the better so I can add this to my subscription
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Re: Turbo Talk Pt. 2
    I pretty sure you still need to do machine work on an 06A block to make that AEG crank work.....IIRC, both the 058 and the 06A block require some overboring to 83mm, since the stock bore is 81mm. However, the 058 block requires some additional work that the 06A block doesn't need
    Someone correct me if I'm wrong, since I don't have any personal experience
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    wait what does a paint job and side skirts have to do with building an engine
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Dec 05 2007
    Quote Originally Posted by 20vpower View Post
    Absolutely nothing. But I am talking end result for entire job (price wise). I want to get it all done at once as my mechanic is a tuner and I think he works in conjunction with others shops for machining engines (but he does builds himself, just not machining). And one would not be able to house the bigger FMIC behind a stock bumper. But if one could achive those numbers with the GT2876r on a 2.0, then there will be no need for a new front bumper with paint job ($600), side skirts to match ($400), and rear bumper ($400). That is my main inquiry (Can one achieve close to 375 whp on a 2.0 w/GT2876r?)
    Veteran Member Three Rings ////D's Avatar
    Aug 22 2007
    847 IL
    if i were you i wouldnt worry about the any of the bumper stuff, just get a smaller fmic core to fit your stock bumper, you might need to trim it a lil but a bunch of guys run fmic with stock bumpers. and im sure those numbers are achievable with that setup
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    You can always take a look at the car GMG posted about, it had a 2.0 liter and a GT2876r. But you might want to search about that turbo, I dont think its going to make anywhere near the power a GT30r can make.
    Dec 05 2007
    I found that link, but it was more of bashing than informative. That is the first and maybe only link that there was for that turbo. He had it dynod with GIAC 91 octane and I plan on running with CTapp 93 and 104. Don't know if that (93 octane) makes that much of a difference, but I would assume though.
    Correction:
    Pump gas with a built 2.0t Motor 370HP @ 6500RPM
    Race gas with a built 2.0t Motor 490HP @ 6600RPM
    *GT2876
    I am just not sure of those numbers are for the wheels. If so, then that answered my question (sort of overlooked those numbers). May I ask you Mike, do you know if those numbers are for the wheels? If so, that seems maybe the best route for me to take. I don't track and this would feed that adrenaline junky that hides inside of me.
    But on the plus side, I am getting my mod thing started. Kind of a good feeling what I learned from this forum and applied to my car. I now have Labree HFC, Milltek exhaust and Ctapp flash. And sports supension w/Neuspeed rear sway bar. Nothing like 600 whp, but yeah . Next stop should be my last. Fully built pushing around 400+ to the wheels.
    Jul 07 2004
    socal
    Those are at the crank. That turbo isn't going to make 400whp on a quattro, to get that you would want a 30r.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    I have a 2.0L with a Hybrid Bullseye S256, SurferForever just finished up his 2.0L and is running a GT28RS Both of us 01.5's I think I was the first on here with a 01 to do a 2.0L and now have over 10k on the motor). I first ran a Full 2860rs with the 2.0L. Without a 30r you're not coming close to 400whp, as Mike indicated all ready. You're also going to need to part with everything you've gotten already exhaust wise and go 3" to achieve 400whp.
    FYI I'm at 397 at the crank 310 at the wheels with my setup and only 18psi on Pump.
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    the GT2876r turbo is a not a very good streetable turbo and you will make no where close to 400whp. If you want that much power GT30r+ is what you need.
    a little info about the GT2876r from 034...
    In reality, this turbo is rather unbalanced, as that little turbine housing causes spoolup far faster than that big housing is ready for, causing surge. As such, Garrett recommends against using this turbo in most street performance applications. However, a high revving, very small displacement four cyl could make use of it, as could an asymmetric application (think single turbo V8, with only one bank feeding the turbo).
    Jul 07 2004
    socal
    Quote Originally Posted by AudiRacerS4 View Post
    Yeah thats how most of the turbo world has felt about that turbo since its bascially a GT35r with a GT25 exhaust side. Just not a good match for the 2 sides. This turbo has been around for a long time and even when it first came out most people did not have anything good to say about it.
    BTW guys I can now offer the new Borgwarner turbos since Full-race now offers them on their site.
    Oct 28 2006
    yeah I've never seen anyone post about using a GT2876r
