Results 1 to 39 of 39
    Dec 06 2007
    Another Freakin Peoblem!!!!!!!!!!!
    I wanna throw this car off a cliff man, i'm losin it! ok so now every time i start my car in the mornin and stuff i start to drive and my "BRAKE" indicator starts flashing and beeping the handbrake is down and i don't think it's sticking i get on the freeway and it randomly starts doing this! on the street everywhere! i have to stop turn off the car lock the doors wait 30sec and then go to stop the problem! any ideas?? and great my VAG doesn't work so i can't use that either!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    Re: Another Freakin Peoblem!!!!!!!!!!!
    prob your pads are going or there is not enough fluid in the reservoir
    BetaAlphaTau member #19
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    Bad ABS module? I say this because when you're vagcomming the ABS module, you get this flashing beeping brake warning light to warn you that ABS is currently disabled.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    Low fluid
    <<NO SIG>>
    Dec 06 2007
    well my pads and rotors have like 5k on them! i don't think i've ever flushed the fluid though, i guess that could be it, anyone know a DIY on how to flush it??
    -Kirk
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    doubt it is a problem with needing to flush.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Dec 06 2007
    ^^no no what i meant to say i noticed my fluid was low but instead of just adding on i would rather flush it and add a new one!
    -Kirk
    Apr 24 2005
    E55 AMG, CTS-V
    gotcha. My clutch fluid resevoir is low, need to add some. Gotta figure out what to use though since it says mineral oil on the cap.
    ~David~
    CTS-V 9.6@148
    Feb 14 2008
    xxxx
    Standard process is to have someone press the brake pedal as you open and shut the bleed valve at each wheel. PITA and can damage the master cylinder if your buddy pushes the pedal too far down (some use a 2x4 under the pedal to avoid this.) But really, the best way to flush is a Motive power extractor - makes it a one-person job and less chance of messing up the process.
    Dec 06 2007
    ^^please explain!!!! and Dave, the mineral stuff is the same for the PS fluid something called Hydrolikol Minerol from Audi/VW i couldn't find it at any auto parts store but some guy at the dealer gave it to me as a freebie haha!
    -Kirk
    Apr 24 2005
    E55 AMG, CTS-V
    yeah I don't have a dealer within 2 hours of me since I live in the Florida Keys and the closest one is in Miami. They gotta have something at one of the damn autoparts stores!
    ~David~
    CTS-V 9.6@148
    Dec 06 2007
    ^^PM i'll try to get u one for cheap and i'll send it to u if u want!
    -Kirk
    Apr 24 2005
    E55 AMG, CTS-V
    thanks but for that hassle I could just order it online somewhere im sure. Ill check ecs tuning
    ~David~
    CTS-V 9.6@148
    Dec 06 2007
    ^^forgot there's the web doh!
    -Kirk
    Veteran Member Three Rings Noodle's Avatar
    Oct 16 2007
    Pittsburgh, PA
    Mine does it to. It has something to do with your brake lines (I believe).
    I could be wrong. Mine did it all the time in the winter. Barely does it now that it's warmer.
    Dec 06 2007
    ^^ya check ur fluid i just checked mine and it's nearly empty!
    -Kirk
    Mar 09 2008
    Florida
    Im in Broward drive up to my garage and we can do it
    <<NO SIG>>
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Quote Originally Posted by A4 TSCHUSS View Post
    The Keys are gay. Pun intended. 2 hours to an Audi/VW dealer.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by dirtybrd View Post
    Key West is gay, not the keys in general! Forget 2 hours to the dealer, its 2 hours to anything but the water!
    ~David~
    CTS-V 9.6@148
    Dec 06 2007
    so any DIY's??
    -Kirk
    Nov 24 2004
    MOntreal
    what are tou complaining more gays means more desperate women
    Dec 06 2007
    ^^true and not true, last time i checked which was like never women love hanging out with gay people! who knows what goes on!
    -Kirk
    Nov 24 2004
    MOntreal
    pretend you are and then you sneak it in
    Dec 06 2007
    ^^perfect game!
    -Kirk
    Nov 24 2004
    MOntreal
    I would love living there wanna see what my life looked like for like 6 months??
    Nov 24 2004
    MOntreal
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by 20vturbo View Post
    what is that all about? It isn't like that there right now is it Is has been 90 degrees everyday here!
    ~David~
    CTS-V 9.6@148
    Nov 24 2004
    MOntreal
    and a couple of unlucky bastards
    Nov 24 2004
    MOntreal
    not right now is summer for another 2 or 3 months and then it starts again..Last winter we got it in the teeth, was the worse ever seen soo many crashes, truck and cars the just flew in the most awkward positions
    Apr 24 2005
    E55 AMG, CTS-V
    screw that, I will stick to the sunny year round, pimp the car with the 19s year round, go to the beach nearly year round weather here in Florida
    ~David~
    CTS-V 9.6@148
    Nov 24 2004
    MOntreal
    i have a whole album on facebook it's called roadkill :)
    I go 60 70 mph in that shit, you just need god tires and never touch the brake and hold the damn thing on the road at any price..and it works, i never had any crash
    Nov 24 2004
    MOntreal
    yeah and when you get a damn hurricane your 19's will hydropimp
    one good thing here is the ski, it's fuckin awesome
    but I intend to move down to florida it's just so hard for a canadian to get papers
    Dec 06 2007
    ^^hydropimp?? haha! souds like spinning in place like spinners!
    -Kirk
    Mar 21 2006
    Lakeland, FL.
    Black ice FTL!
    I'm back bitches!
    Dec 06 2007
    so like anyone figure out how i can do this??
    -Kirk
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Your peoblem is low brake fluid, as has been mentioned.
    Dec 06 2007
    ^^i knew that but what type of fluid should i add or can i flush it myself??
    -Kirk
    Sep 20 2006
    Baltimore
    It's recommended that you flush and not just add fluid. What type of fluid depends on what you want to do with the car. Are you running stock brakes? Are the pads low? Do you plan to track the car at all? HPDE?
    Searching for "brake fluid" in B6 A4 returns 422 threads.
    Dec 06 2007
    ^^too lazy and tired to search, still repainting my door handles since 12 today! i have stock brakes with rotors/pads that have maybe 6k on them they're basically brand new! so what fluid to use? i might track my car soon though so the better the performance the better!
    -Kirk
