Results 1 to 4 of 4
    Senior Member Two Rings bhunt17's Avatar
    Mar 26 2007
    2001.5 S4
    San Jose
    Starting problem
    so I have been having this starting problem recently. Whenever my car sits for awhile it takes about 4 cranks or so before it will start. Once it warms up it starts fine until I let it sit for awhile. Other than that it drives fine. Any suggestions on where I should start or look? On a side note if I'm driving farther than about 20 miles at one time I get a trouble code of P0116. Short trips never cause it to come on.
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: Starting problem
    Looks like you need an engine coolant temp sensor both from what is going on and what the code is saying.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Mar 26 2007
    2001.5 S4
    San Jose
    So the ECT has an effect on the car starting?
    Established Member Two Rings johnp69's Avatar
    Mar 07 2007
    2011 Range Rover Sport 2016 Nissan GTR
    Pittsburgh
    bump...im having the same problem right now...replace the coolant temp sensor but the car is still reading it is -15 degrees and last i checked its about 80 today...still wont start any suggestions?
