Results 1 to 9 of 9
    Nov 26 2006
    Memphis, TN
    Need some wiring help (nitrous)
    I am putting my nitrous system in my car to go along with my water/meth system. So i dont have to go searching through wiring diagrams I was wondering if someone could help me out. I am looking for a tach signal and throttle position sensor wires. I am mounting the window switch inside the cabin so access to the wires inside would be preferred.
    Just a side note. I am just bending some 3/16 aluminum hard fuel line to make a custom spray bar to cover the intake manifold. When the purge button is pressed, the nitrous will go through the spray bar and cool down the intake manifold. Seems like a good idea for these hot running S4's
    I have a 2007 S4 for wiring purposes.
    Nov 26 2006
    Memphis, TN
    Re: Need some wiring help (nitrous)
    here is a link the the kit instructions
    http://www.holley.com/data/Products/...99R10408-1.pdf
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Cool! How long will this install take?
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Be careful. My buddy blew his S4 engine with nitrous.
    Veteran Member Four Rings ItzDarrellS4's Avatar
    Jul 14 2007
    A Sedan, a Hatch, a SUV, and a Pickup
    The Live Free or Die
    what size shot are you planning on?
    mpg's lol
    Nov 26 2006
    Memphis, TN
    I am only planning on running a 50-shot.
    Please post information about wht happened to your buddy's engine. Was it a B5? Also was it a wet or dry shot. Nitrous can be very bad if done incorrectly but great if done right.
    The install will take me about a weekend as I plan to take my sweet time and not rush at all. But I have put kits in in about 3 hours (this is for a wet kit, a dry kit is much easier)
    I am also running Wateer/meth injection so detonation is little to no problem.
    Aug 11 2007
    California
    Quote Originally Posted by OneFastBMW View Post
    I don't know much about it but he has a B6 S4. I also know he's an idiot and he put a 180 shot in there. Needless to say, it messed up his engine. He got that part replaced and took out the nitrous, but the previous explosion caused another problem resulting in a 2nd blow up just recently.
    Account Terminated Four Rings
    Apr 16 2007
    New Jersey
    The purge on the intake manifold is a good idea but it will crack it. Going from as hot as it gets to as cold as nitrous can cause damage.
    Nov 26 2006
    Memphis, TN
    Quote Originally Posted by 91gl View Post
    I will need to do some testing with a infrared thermometer to see how how the intake manifold actually gets. I cannot see it getting over 200 degrees F.
    Yes, a 180 is a bit much for an aluminum V8.
