Results 1 to 10 of 10
    Senior Member Two Rings safab's Avatar
    Apr 25 2007
    ca
    New DD and future BT/BAT...also a question about compression
    So while browsing craigslist I came across a 97 a4 1.8tQM w/ ~235,000 miles that supposedly had a bad turbo, bad cat, possibly o2 sensor(s) and lastly a blown head gasket also. Owner says the car drove fine until 40K miles ago until the turbo blew...even then it drove fine until a few K miles ago when the CEL came on and the mechanic diagnosed it as mentioned above. I couldn't resist and was able to snag it really cheap thinking I could go BAT on it later in the year and for now just spend a few bucks and repair and use it as a beater w/ the blown turbo and all for the summer.
    Anyways, picked it up and drove it around all day w/ A/C on and no overheating or any issues that I could tell whatsoever, besides no power and a CEL. I got her and home and did not find any oil in the coolant and no coolant in the oil. Hooked up a boost gauge and the vaccume reading is good. Also did a compression test and got (cyl 1-4) 185, 190, 180, 190. I searched and from what I read that is pretty good??? for a 1.8t. So, what i'm thinking is that I got lucky....that the turbo blew (a oil seal) and oil has been leaking into the exhaust fouling either an o2 or the CAT thus the CEL. What do you fellas think? Am I on the right page here?
    I've got a 3071r/550's/FMIC and 034Ic sitting around so might as well pick up a manifold and throw that in (go BT for onw) and run it for a while till it pops........if the engine is good.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: New DD and future BT/BAT...also a question about compression
    How much did you get the car for if you dont mind me asking.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Three Rings spxxx's Avatar
    Jul 31 2007
    bay area
    that compression test looks good, mine was 158, 160, 165, 165....
    its not the pressure that matters but the difference between them, take the highest pressure and multiply by.75 to get the lowest possible allowable.
    Laser Red 1.8tqm GT2X pc16 --> sold
    REVO + 034 Goodies >>> B6 A4 1.8tqm
    Apr 25 2007
    ca
    1500
    Cool...I guess instead of spending the money on repairs right now I need to find a manifold.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Sweet deal.
    Jim
    I Do Werk.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by spxxx View Post
    Well the pressure still matters since that is what compression the motor has and usually means there is a good amount of wear, plus the motor is not running at 100% anymore unless more timing is being added to make up for the lower compression.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    ur gunna have to build that motor to run a 3071r... i dont see why you would wanna blow it up and have to find a whole new engine when you put a rod through the block.. and nice deal on that! got lucky, must feel nice. ha
    Jul 31 2007
    bay area
    so what is the "optimum" compression pressure for our engines?
    Apr 25 2007
    ca
    Quote Originally Posted by njm23 View Post
    I've already got a spare motor and all parts for a 2.0L build...just need to clearance the block and assemble the motor. So I'm not worried if the motor pops. Besides, I don't have to push the 3071r to the max...I should be ok around 300whp hopefully on the stock block.
    Jul 07 2004
    socal
    Stock engine is 185.
