Results 1 to 6 of 6
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    thanx chicago performance (CPT)... ER sidemounts
    huge thanks to those guys...went up to chicago yesterday and decided to call chicago performance. thought id check and see if they could get me on the dyno. turns out it had a car on it all day but Al said bring it by, we'll take a look. no appt and he got me right in. pointed out and fixed a few problems and took the time to explain everything. me and my girlfriend hung out for 3 hours and never felt like a bother lol. the problem is not solved but Al definitely helped eliminate some possibilities (ecu being one of them). im confident if i can find the time to leave the car they'll sort it out. oh and while i was there i decided to pick up a set of intercoolers
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: thanx chicago performance... ER sidemounts
    what problems did you have?
    B5 S4 AWE Stage 3 - sold
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Do you mean CPT?
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: thanx chicago performance (CPT)... ER sidemounts
    Sweet!
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Nov 03 2006
    Several :-)
    Lisle, IL
    Al at CPT is one of the best in the country hands down. You couldn't make a better choice bringing your car to him.
    Registered Member Three Rings updaboost's Avatar
    Mar 08 2006
    S4, 997 4S & S2000
    Chicago
    I only hear good things about Al..I hear he has a sweet 996tt..should go vist him and get my vast fueling sorted out..
    01.5 Nogaro Blue S4, 6sp
    VAST Stage 3 - Piggies - Neuspeed - RS4 Clutch - Samco - Hyperboost DVs - AMS TBB - Stratmosphere SS - Flik Justice/SSR Comps - Vogtland - AWE DTS - H-Sport Sway
    360whp/400wtq
