Results 1 to 9 of 9
    May 25 2008
    san francisco
    Any difference in 1998-2000 1.8t engine to a 2001 1.8t?
    Just wondering if there is any differences in 2001 1.8t engine as apposed to the 1998-2000 1.8t. Was planning on picking up a 2001 a4 with a blown engine (probably due to oil sludging) and was going to install a rebuilt engine. Ebay lists one, but only for 98-00. Is there any differences?
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: Any difference in 1998-2000 1.8t engine to a 2001 1.8t?
    Yes... Quite a few... Search for em... Just to list a few. Wideband O2, DBW, SAI, MAP sensors, the list goes on...
    ΜΟΛΩΝ ΛΑΒΕ
    May 25 2008
    san francisco
    Thanks! If all the electricals were switched over with another long block, will that work?
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    1996-2000 AEB n-DBW 150hp k03 chip only
    2000 ATW SAI, DBW, MAP 150hp k03 Flashable
    2001 AWM SAI, DBW, MAP 170hp k03s Flashable
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    dont forget about those port sizes
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    96 or 97-2000 has a different block than 2001.
    Get a motor from a 2001 car and MAKE SURE the donor car had the same type of transmission as you, meaning, if you have a manual, donor car MUST HAVE BEEN manual.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Senior Member Three Rings BaconBait's Avatar
    Feb 17 2006
    In my car with a shotgun
    1996-2000 AEB - belt driven oil pump, external water pump, large port
    2000 ATW - belt driven oil pump, external water pump, small port
    2001 AWM SAI - gear driven oil pump, internal oil pump, small port
    -Craig
    Built: 2.0L Stage 4 3/4%
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Does 2000 ATW have VVT?
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    no. 2001 started vvt
