Results 1 to 15 of 15
Thread: stasis c/o
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    stasis c/o
    I usually search, but im at work and the proxy server im using is really really slow. just need to know if i can adjust my rear height without taking them off if i have a spring compressor?
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Re: stasis c/o
    Don't think any rear coilover set-up is on-car adjustable for our vehicles. Reason being is that we don't have a true coilover set-up in the rear. The shocks are separate from the springs, making the springs hard to adjust.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: stasis c/o
    On the Stasis rears you need to drop the sub frame to adjust.. sorry
    Sep 20 2004
    Paradise Valley, AZ
    Re: stasis c/o
    do you think if i raised the rear 1/8 of an inch would i need another alignment?
    Senior Member Three Rings topcat's Avatar
    Apr 09 2007
    2002 A4 1.8T
    Atlanta
    Re: stasis c/o
    it will be hard because the perch, if you remember if you installed them, sit down in a hole, so to speak of. Depending on how far down the adjustment ring is, you probably can't get to it. When I initally put mine on, it was too low, and we took it out and adjusted it, and prayed it sat right when re-installed.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: stasis c/o
    I'm no expert, but I still haven't got an alignment and everything is still good, no extra tire wear, drives nice and straight with hand off wheel.. so I would think an 8th in the rear would not require a realignment....
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Re: stasis c/o
    I may be wrong, but with spring compressors you may be able spin the perch without dropping the subframe.
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: stasis c/o
    you CAN adjust it on the car.... but it is such a pain in the ass that it is not worth it
    even with a spring compressor, there is not really enough clearance to get the tool on.... plus the tool sucks
    you will end up splitting all of your knuckes for two turns
    you can pull them out, adjust them, and re-install them in about the same amount of time and a tenth of the frustration
    heres how to uninstall them incase you didnt do the install yourself
    http://www.a4mods.com/index.php?page...coilovers.html
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: stasis c/o
    Quote Originally Posted by pondside36 View Post
    thats because of my magic installation skills lol
    - Clint
    Sep 20 2006
    Baltimore
    Re: stasis c/o
    for Clint's skillz
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    Re: stasis c/o
    My mechanic adjusted the rear by compressing the sprintgs in place. It can be done. I had done a bit by hand before and it is a bitch. At some point, the spring is compressed enough that it's very tough to turn.
    It "seems" that the rear wheels go up/down without changing angle (camber) much so you may be fine without a realignment for just playing with therear a bit.
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Sep 20 2004
    Paradise Valley, AZ
    Re: stasis c/o
    thanks guys. ill let you know how my experience goes after i tackle it. its a 113 degrees in phoenix today and Im hiding indoors.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: stasis c/o
    Good luck.. and Clint, you definatly have skillz...
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: stasis c/o
    like nunchuck skills? or bowhunting skills?
    - Clint
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: stasis c/o
    Like Mt. Bike Jumping skillz... sheeessh
