Results 1 to 15 of 15
    Feb 15 2007
    marimont
    c/v /axle question
    To start I just replaced the cv boot. Put it all back together and there is clunking. Jack it up and rotate in reverse and it rotates perfect. Rotate it in the drive position and there is a slight clunk it makes one a revolution. Did I not install the cv boot correctly? I know it's not an issue of the splines. If it was it wouldn't allow me to assemble it back together. Unless I used blunt force to.
    Any help is appreciated.
    Dec 14 2006
    Halifax, NS, Canada
    Re: c/v /axle question
    when i did this my issue is that i pulled the inner out and some of the balls had fallen out
    made a similar sound every rotation
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Feb 15 2007
    marimont
    Were you able to put it back together or do I need to replace the joint now?
    Dec 14 2006
    Halifax, NS, Canada
    got a whole new axle because i needed a new outer end. I am sure its fixable the balls just need to go back in.
    NOW DEAD :(
    Feb 15 2007
    marimont
    Just out of curousity. How would the bearings fall out that are held in by a ring?
    Dec 14 2006
    Halifax, NS, Canada
    No clue but it happened when i did lower control arms so some force were put on... probably the ring popped out of the grove.
    NOW DEAD :(
    Feb 15 2007
    marimont
    Another symptom is that the axle assemblies (both sides) spin freely when the rear is lifted. When it is lowered and starts to roll it grinds violently.
    Dec 14 2006
    Halifax, NS, Canada
    yah sounds exactly what happened to mine.... then it went pop and i couldnt drive it. take a look before you try more :P
    NOW DEAD :(
    Feb 15 2007
    marimont
    I'll check that out. Even know that is the last thing I wanted to hear after doing all that lol.
    Feb 15 2007
    marimont
    So I go to take the cv back off and and when I insert the hub bolt to tighten done to pop the cv joint. The axle just spins with it in gear and the other rear tire still on the ground. Did something else happen to cause this?
    Senior Member Three Rings j2da's Avatar
    Jun 18 2007
    00 1.8tqm
    Massachusetts
    Quote Originally Posted by Squarrl View Post
    x2. mine was making that clunk sound, then before i knew it i was stuck on the side of the highway.
    | koni coils | 18"rs4 | ebayFMIC | giac k04(gpop) | Forge007 | ecode testpipe | rock chips | negative deviator |
    Feb 15 2007
    marimont
    Well it wasn't the bearings that fell out. Somehow the inner cv disconnected from the diff. How that happened? I have no clue. Now I'm trying to source a 12 pt torx to remove the damn thing.
    Dec 14 2006
    Halifax, NS, Canada
    The inner joint was what i was talking about. I think you will find the balls for the inner not all in place.
    NOW DEAD :(
    Feb 15 2007
    marimont
    So I can just put it back together?
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    yes you can, and it is a BITCH to do, very frustrating. Unless you get lucky, ha.
