Results 1 to 10 of 10
    Senior Member Three Rings theboogieman1's Avatar
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    swimming like a fish?
    So I was on my way to work today and noticed my cars back end kinda wobbling around side to side like a fish. I don't have time to search this down so if anyone has felt this or knows what it could be please let me know. I'm hoping this means it's time for a suspension upgrade.
    02' Black S4 6spd / JHM "Stage 3" / JHM "Solid" Shifter / VAST Stg. 3 Clutch and LW Flywheel / Vogtland GT's / 034 Track Density Motor Mounts/ AWE DTS / JHM FMIC / Hawk HPS Pads / H-sport sways / SSAutochrome TB Exhaust
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: swimming like a fish?
    Wheel bearing. . .?
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    im thinking an alignment is due.
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Quote Originally Posted by gaspeedracer View Post
    I think I just had my alignment done. The car doesn't pull to any side so not sure if that's it.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Before you go home I'd check to make sure the lug's are all on tight so the tire doesnt fly off while your driving down the road. That'd not be good.
    I know its probably a given but did you check it wasnt a flat tire?
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Senior Member Two Rings Tokin's Avatar
    Nov 28 2007
    Audi S4 and Tiburon
    Daytona Beach
    ^^ Yeah that could be nasty. My mom had a lot of road noise and some strange side-to-side pull from the rear wheel one time, after she had a bunch of problems with this shop. I checked the lugs, turns out the mech that worked on her car a few days before HAND TIGHTENED the lugs on that wheel. That's life and death shit
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Check tire pressure. I have the same thing going on right now. I think it might be a combonation of things tho. Balding tires and the suspension needing refreshed. Ill keep you updated on what fixes it.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Well damn, that's a good call. I just got my tires rotated about a week ago. That's what I was thinking when it was happening. It felt like my tire was wiggling back and forth about to pop off, but then it would go away.
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    Check the rear brackets and mounting points on your H-sport sway bar. You can see them without having the jack up the car. Just take a knee.
    I experienced the "floaty swimming" feeling from the back of the car when the bolt from one of my H-sport brackets vibrated out.
    B7 S4 Avant
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Quote Originally Posted by BlackS4TT(Josh) View Post
    Good call, thanks man!
