Results 1 to 8 of 8
    Sep 11 2007
    Dirty Jersey
    F.S. 1.8T HKS BOV kit with hotside, cold side and recirc mounting parts
    used HKS SSQV valve with mounting harware
    can be installed in the following ways:
    stock location using VW/ Audi adapter and recirc fitting for DV use
    stock location using VW/ Audi adapter and return line plug for BOV use
    or installed on the cold side before the throttle body using included hose, and flange mount adapter
    $125 shipped to the lower 48 paid with paypal
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Sep 11 2007
    Dirty Jersey
    Re: F.S. 1.8T HKS BOV kit with hotside, cold side and recirc mounting parts
    since it was asked on the other board, I think that I should say its a real HKS valve
    Established Member Two Rings gotboost?!'s Avatar
    Oct 16 2007
    Chicago
    how many miles on the bov and what model were u running this on ex. a4, jetta,gti ??
    "god gave us turbo lag to give V8's a chance"
    98 Audi A4 1.8TQM
    Sep 11 2007
    Dirty Jersey
    not 100% sure of how many miles are on it, are these really wear parts?
    originaly it was fitted to a mk4 VW , but the silicone hose I'm including is off my 1997 AEB A4 , its pretty universal in its application though as it has the standard 1" DV fittings included
    Sep 11 2007
    Dirty Jersey
    bump
    Oct 16 2007
    Chicago
    so your saying it will fit on my 98 aeb a4 because i see you have a 97
    98 Audi A4 1.8TQM
    Sep 11 2007
    Dirty Jersey
    Quote Originally Posted by gotboost?! View Post
    I don't know of any reason why it shouldn't fit a 98 AEB as it fit my 97 AEB just fine, the cold side is a bit tight space wise, I clocked the valve such that the valve clears the cruise control vac actuator and the face lift headlights I'm running, so you pretty much have to bolt it in between the IC and the TB and you're all set to whoosh, it even includes the right length vac line to run to the manifold
    Sep 11 2007
    Dirty Jersey
    sold, thanks
