Look, my first post was simply asking a question that I myself could not find an answer to, one that perhaps a fellow Audi owner could… ironically, the very reason why forums like this one exist. (Imagine that?!) I was not trying to upset anyone or call them out. On the same note, I was also not looking to be belittled by them either. But, since you want to play that way, let’s have some fun…
Useless… comment #1
Originally Posted by
CO AVANT
It's a better oil plain and simple, no need to get into details at this point.
Thank you for such an informative and technical reply. But I don’t see any facts here… only one persons opinion… and what makes it better than mine? It takes very little knowledge to make a stupid comment.
Useless… comment #2
CO AVANT
There are many variables that can make or break an oil and its quality.
No kidding? If not then all oils would be the same wouldn’t they?
Useless… comment #3
CO AVANT
If you read the website I posted above in extent you would know this. I don't need to repeat information you can click on and read for yourself.
1) Prior to my first reply\post, I did search and read on those sites and several others for over 2hrs, and did not find a suitable answer.
2) you posted an entire forum, not a specific thread pertaining to my question… or anyone else’s. Where is the help in that? You might as well have said “go search vortex, I’m sure they have your answer somewhere.”
Somewhat informative, but still useless in this instance… comment #4
CO AVANT
I only use basic castrol gtx 5w30 dino oil for engine break-in's since you don't want a slippery oil for break-in (so your piston rings seal to the fullest) and you are just gargling and spitting oil since the intervals on break-in are so many (at least how it should be done), so I don't personally have anything bad to say about PAO based oils,
When did I ask anything about breaking in an engine? And what on earth does it have to do with a PAO base stock, that has any relevance to my question?
Narrow-minded… comment #5
CO AVANT
but I know what works best after break-in..... high end modern race cars use that full ester blend, so it must be what's working best right now under extreme conditions.
It might be what works best under extreme conditions… but there are a few things to keep in mind here. Many “race engine” oils contain little to no detergents (detergents keep motors clean, and particle build up away), only anti-wear agents. Their primary concern is how much horsepower they can produce, not how many 100s of thousands of miles can it go before it is worn out. Races are won by how much power you make and how well you put it to use, not by how long it lasts… “race engines” see frequent oil changes as well (can you say: after every race?) street motors do not. They are also torn down, *cleaned*, and rebuilt often, so any deposits that may have accumulated would simply be washed away… further lessening the need for detergents. Why use something containing detergents, that might be slightly less “slippery” and lose possible HP when you don’t have to?(it might cost you a win). A 300k+ rebuild means nothing …but, for a street engine, it’s a worthwhile trade off.
Lol @ “high end modern race cars”… For the record, we are talking about an engine made by Volkswagen, not Ferrari… this is the same company who makes such things as a “rabbit” & “beetle”. “High end” - NO, “Modern” - SOMEWHAT, “Race car” - HARDLY
Simply untrue… comment #6
CO AVANT
A lot of your normal off the shelf oils have gone down in quality (lubricant properties, etc) over the past years from what I've read and talked about with some fellow audi mechanic friends.
If this is indeed the case, why keep oil chemists on the payroll? Wouldn’t they just cut into the company profits? The truth is, oils are constantly being improved\reformulated. Yes new oils come along, and outdate the older ones, but when you compare “apples to apples” (older Castrol GTX to newer Castrol GTX) the new one will almost always be better than the old. Oil companies are constantly improving old formulas to be the best they can be at their particular price point. As oil technology progresses, newer types of oil come along and outperform the older outdated types. For instance... Castrol Syntec vs. GTX… GTX does not perform any worse… Syntec just out performs it.
There is only one instance where this might not be true… (I say might not because it is third-party information to me and I don’t know how accurate it is.) The oil in question is Mobil 1 0w-40… from what I understand, it was not reformulated, but declassed from “type IV” to “type III” due to lawsuit issues with Castrol. From what I understand, Mobil was marketing it as something it never really was, and Castrol called them on it... once again I’m not sure of the accuracy on this, and I have never bothered to find out, simply because I would never run it in my car either way.
If you have any comments, please feel free to enlighten me, I would like to hear any and all information… this is a quest for knowledge after all.
Thank You.
