Results 1 to 10 of 10
    Veteran Member Four Rings itsdarrow's Avatar
    Jan 27 2006
    Nyc
    Exclamation So I want to go bigger than my gt28rs
    Whats the best and most cost efficient way?
    a) i drop in some rods, build my head so i can rev the piss out of my car and take advantage of the larget turbo(gt30 series not sure yet)
    b) Build the engine to 2.0 (which is alot more labor intesnive i hear) and keep stock redline.
    i cannot do both cause it is to expensive
    black B6 a4, 18x8.5 anthracite bbs ch, Full frame gt28rs kit, Unitronic 440 file, high on meth.
    Feb 17 2005
    Sarasota, FL
    Re: So I want to go bigger than my gt28rs
    Do you have a full 28RS, T25 or T3 flanged, or an Elim?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Here is my take on the subject (from an engine-build only standpoint):
    Bottom end build.
    1) bare minimum: Swap out the stock connecting rods for IE rods. Head has to come off for this job.
    2) step two: You can do all of step one plus all new bearings and seals, cylinder hone, new piston rings, IE rods etc...
    3) step three: step two but forged pistons with 20mm wrist pins (piston rings included) and corresponding connecting rods
    4) step four: cylinder bore and hone, new crank..... 2.0L stroker motor
    Headwork:
    1) bare minimum: basic valve seat grind, aftermarket exhaust valves and new exhaust valve guides (if needed).
    2) step one plus aftermarket intake valves and intake valve guides (if needed)
    3) step two plus aftermarket springs and retainers
    4) step 3 plus aftermarket cams
    Add in port & polish on any of those steps if you so desire. Add in headwork to any of the bottom end steps.
    -Doug
    Registered Member Two Rings
    Jun 12 2008
    900hp '99 Camaro SS / '04 A4Q
    So*Cal
    It won't be cheap. Whatever you do, don't skimp on quality of build or a step because of cost. It will cost much more in the long run if something breaks or the motor blows.
    Go with a reputable shop (especially for your bottom end) that knows how to work with 1.8T engines. Again...this is not an area you want to skimp on. Quality quality quality is the key here.
    Fuel is also important...however BIG you go, make sure your fuel components are up to the task as well.
    Good luck!
    900hp '99 Camaro SS: - Slightly modded
    '04 B6 A4 Quattro - Stock for now
    Jan 27 2006
    Nyc
    i have the full 28rs kit. not sure on the flange it is the first revo/ecode kit, the one that is mafless. I believe that used to run this kit befor the 71r
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by itsdarrow View Post
    A set of IE drop in rods and this would do the trick
    http://www.audizine.com/forum/showthread.php?t=216786
    Jan 27 2006
    Nyc
    what kind of powerband were you seeing whit that turbo shawn? also just rods and i would be fine?
    Jan 27 2006
    Nyc
    bump for some help from people with know how!
    Jun 30 2007
    Raleigh, NC
    i'd do rods and exhaust valves/guides as a minimum if i were you.
    and do a 3076.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    A 1.8 with a 8500 rev. limit, cams will be a must, and 3076 would work nicely. If you don't up the displacement you need to up the RPMs.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
