Results 1 to 3 of 3
    Registered Member Two Rings
    Feb 21 2008
    Rahway, New Jersey
    I need to replace ignition switch. Please read.
    A buddy of mine gave me the whole steering wheel column out of a 00 s4.It looks exactly the same as the one in my 96 a4 to the t. If i remove the ignition switch from the s4 one and try to put it where my 96 one is now, is it just plug and play?
    He also gave me the key for the new ignition also. Would it be easier just replacing the whole column cause I have the whole thing in one piece.
    Thanks
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Re: I need to replace ignition switch. Please read.
    not really sure bout this but you can call the dealership and see if the part numbers are the same and go from there
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    i dont know, but wouldnt you need 2 keys, 1 for the doors and 1 for the ignition because they are different unless you use the clicker to unlock the doors
