Results 1 to 12 of 12
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    Help with Coilovers!!!
    I just bought a set of Eibach coilovers and I have noticed that in order to even everything out in ride height, the front threads are way different from each other and so are the rears. The front right has 4 threads left on the coilovers and the left has about 20? Same with the rear? Is this normal? Does the car have more weight to one side? Also it seems that I can't lower the front left anymore...I keep lowering the perch but no real difference in ride height after 25" total? Also there is a squeaking noise coming from the same side. Very noticable over bumps in the road? Any thoughts will be greatly appreciated. Thanks!
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Re: Help with Coilovers!!!
    I would contact Eibach and/or a local garage... 1st Eibach. See if you have a flawed product. I would imagine the fronts to be the same(threadwise).
    Did you do the install yourself?
    If so, take a couple of buck down to the local garage, and have them look over your work. Maybe they will notice something that you just looked past...
    Drive the car as little as possible right now... don't want any un-needed damage.
    J
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    May 23 2008
    Columbia, SC
    I know I need new upper control arms...could that be effecting anything?
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    The squeeking noise could be coming from this nut, make sure you tighten it fully using an allen key and socket (18 mm). Other than that, check the rubber spring seats (if you used them) to make sure the springs are seated properly. If you didn't use the spring seats, try using them.
    The coilover writeup here is quite helpful as well.
    http://www.audiworld.com/tech/wheel.html
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    May 23 2008
    Columbia, SC
    where is that nut exactly? Nevermind...I got it.
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    I have Eibach C/O's and NO you should not have that big of a threard difference from one side to the other.
    Feb 12 2008
    01' S4/ 98' Boxster
    Lake Oswego/Corvallis
    Just get Stassis coilovers and forget about everything! haha
    May 23 2008
    Columbia, SC
    Quote Originally Posted by audiwop View Post
    How do your C/O ride? Mine are very harsh. Also, what do you think could be causing the difference in ride height...I reinstalled everything and compared to the other front assembly and they are exactly the same?
    Veteran Member Three Rings quicksilver_S's Avatar
    City that never sleeps
    I just installed my eibach CO as well. No issue whatsoever. The thread are pretty much even and everything seems solid. I would check your installation.
    May 23 2008
    Columbia, SC
    well i just reinstalled and changed out the control arms with brand new ones...eliminated the noise issue but the threads on the coilovers are still about .5" to 1" lower on the drivers side then on the passengers side...both front and rear? I raised the height exactly an inch on all 4 sides and the final ride height was only about .5" different from when I raised them? Weird I know...I have no clue whats going on...all numbers on the springs match with opposite sides. I don't feel anything wrong with the setup except that the ride is pretty harsh, but at least its not as jumpy anymore since I raised it up some.
    May 23 2008
    Columbia, SC
    Ok guys...look at this picture and tell me if you still need to use that black cover that is located at the top of the strut. The picture only points to the two others. I believe that might be my issue because I put the black piece on the new coilovers and then put the bumper/dustcover over that. Thats ow the old struts were set up but I believe they are getting stuck on the threads and not allowing the car to lower on that one side?
    May 23 2008
    Columbia, SC
    bump
