Results 1 to 7 of 7
    Established Member Two Rings OettingerAvant's Avatar
    Jan 23 2005
    '04 Avant Quattro
    Vancouver
    Do the B5 S4 calipers work wtih the stock B6 A4 3.0L carriers?
    wonder will the B5 S4 front caliper will fit with the B6 A4 3.0L carrier?
    cant find info TIA
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    Re: Do the B5 S4 calipers work wtih the stock B6 A4 3.0L carriers?
    Nope
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by OettingerAvant View Post
    cant find info TIA
    You don't need the 3.0 carrier. The B5 S4 calipers and carriers are one piece. Just buy the calipers and they bolt right in.
    Sep 16 2005
    Quote Originally Posted by Condo View Post
    You sure about that on a 3.0?
    -Karl
    USP CLUB MEMBER #8
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by Redgoat View Post
    100% sure. The mounting location for the carriers is the same on the 1.8 and 3.0. The difference is in the carriers to make room for the difference in rotor sizes.
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    nada
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Sep 16 2005
    Umm if I am remembering correctly they arent the same. A friend of mine who has a 3.0 Just tried to swap some B5 S4 brakes on and had no luck what so ever. Hopefully somebody can chime in with some more intel on the matter.
    -Karl
    USP CLUB MEMBER #8
