Results 1 to 10 of 10
    Established Member Two Rings randylam's Avatar
    Jul 23 2007
    Hong Kong
    Unhappy Big Problems need help!!
    What happens was the car is running stock programme.it feels awsome after the secong stage by the revo and extra file for the bigger injector, but problems occur, after few minutes of driving it goes back the stock performance, so I went to revo dealer have the fault code scan, it came out the o2 sensors problem so change the new sensor and is ok for a while it's happen again!
    So they reflash the programme and change the stock injector and try,is the same, and the worst things is they could not find any fault code this time.
    And now my car is just sitting there a week now no progress!!!
    Any bros can help me.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Big Problems need help!!
    Have them log your car in block 115 and see if your actual and requested boost levels are matching up. What injectors are you running?
    Jul 23 2007
    Hong Kong
    Quote Originally Posted by CO AVANT View Post
    Esc kit-36lbs/360cc injectors
    Feb 12 2004
    Everywhere
    Those injector work but I'd run the newer TT injectors. Old ones were 360cc, new version are 386cc. A program should not just "go back to stock programming" while driving unless they are loaded the 5hr demo flash in it. Do you have anything out of the ordinary hooked up to your cars electrical system? They need to log your car's actual vs requested boost levels in block 115 and log at wide open throttle to see if you are getting the boost levels you should be...
    Jul 23 2007
    Hong Kong
    You mean my stereo and Gps system.
    Jul 23 2007
    Hong Kong
    Co avant:
    Any more things I should look for?
    I will go see the revo dealer tomorrow.
    Thanks
    Jul 23 2007
    Hong Kong
    Any help and advices.
    Thanks
    Feb 12 2004
    Everywhere
    Make sure the software they are trying to load is not the 5hr demo software and is indeed the real thing. They will know if it has taken to your ecu if your requested and actual boost levels match up in block 115. This shop does have access to vag-com and can log your car with a laptop while driving correct? If not then, damn...
    Jul 23 2007
    Hong Kong
    Yes, they do use the vag com to log in while its driving. Today the revo dealer was saying could be the chip from the ECu. They will swapp another chip in and see is the problem of the chip.
    Now they are waiting Revo (UK) headquarter for the programme.
    Thanks
    Jul 23 2007
    Hong Kong
    Thumbs up Re: Big Problems need help!!
    Thanks Guy
    Is all fix, and it feels so good.
    Now hold bar1.4 and highest up to 1.9
    The problem is the ecu chip.
