Results 1 to 9 of 9
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    Can someone help me with this code and problem i'm having
    I feel that my car's accelertor pedal does not keep up to my foot, IE as i rev my motor it does nothing for over a second then reacts???? There was a HUGE delay so i vag'd it and came up with this code below. My car was down for sometime while i did the stage 3 work i am wondering if it has anything to do with the computer or tune??
    Also i just put in a new engine coolant temp sensor so why would it throw a code for that ??
    Address 01: Engine Labels: None
    Part No: 8D0 ÓÓÐ 551 K
    Component: SSP K04 G ROB
    Coding: 06711
    Shop #: WSC 63351
    16165168083968WAU XXXXXXXXXXXXXX
    3 Faults Found:
    18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
    P1639 - 35-10 - - - Intermittent
    18042 - Accelerator Position Sensor 2 (G185): Signal too High
    P1634 - 35-10 - - - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 35-10 - - - Intermittent
    Readiness: 0010 1101
    01 S4 6 stage 3+ speed featuring: SSP CUSTOM TUNED ::x-1 racer::spp efk::ecs pullies:removed AC :apr bipipe::AWE DPS::test pipes::twin 1::h&r coilovers::h-sportsways:K04/K16 zero clearenced extrude honed:oil catch can:FMIC:O34 track density motorand tranny mounts: PUREMS diff mount with power ring: JHM SS kit and linkage upgrade :redline gear and tranny fluid::
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Dec 06 2007
    Calgary, AB, Canada
    Re: Can someone help me with this code and problem i'm having
    Check to make sure the connector is seated firmly and the wires are intact on the throttle plate position sensor. There is also a sensor behind the gas pedal that measures how much throttle you are giving the car. I would also check that sensor.
    Check to make sure the CTS is plugged in.
    Apr 20 2004
    Boston
    what is the cts...
    Dec 06 2007
    Calgary, AB, Canada
    coolant temp sensor
    Apr 20 2004
    Boston
    Marc BBB YGM
    Apr 20 2004
    Boston
    ahh yes cts... it was late when we were posting lat night i was tired..
    Apr 20 2004
    Boston
    Quote Originally Posted by The_Jerbel View Post
    what are the chances my ecu or flash is messed up?? i dont think so but thats what someone had told me?? and also how could i tell??
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    do you have the green CTS? also, when you check the connectors by your TB and TBB, clean them with some contact cleaner... and check to make sure your TB itself doesn't have too much junk in it. Might as well check your MAF too and clean it and the sensor. cleaning actually helps sometimes. especially if you live in an area that has a bunch of dust and crap in the air... like Houston!
    When did you have your ECU flashed? Check your wires connected to the back of you ecu and then to harness of the car and make sure they are seated well too.
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by awdbiturbo View Post
    Chances are quite low, but it's possible.
