Results 1 to 10 of 10
    Junior Member Two Rings
    May 18 2007
    Midwest
    Help! Stoptech or Porsche for a B5 S4??
    I'm trying to decide on a Big Brake Kit. I've got a chipped B5 S4 w/ Bilstein pss9 suspension. I'm leaning towards the Stoptech 332mm kit or the Porsche 993TT kit that ECS tuning sells. The car will see track time w/ club racing events. Any thoughts on a brake setup. I'm trying to order something ASAP...I haven't been able to locate anything used.
    Nov 15 2007
    2001 Audi A4 1.8tM Quattro
    San Diego
    Re: Help! Stoptech or Porsche for a B5 S4??
    My buddy put StopTech on his S4 and never looked back. Good Hunting.
    Senior Member Three Rings AddICTioN's Avatar
    Dec 06 2007
    Houston, TX
    I'm also looking for a BBK. It seems the ECS kit is more for bling/street driving. I hear the rotors crack with track use. Sucks though as this is the most affordable kit. If you plan on doing track days your probably better off with the stoptech's. If you can wait one of the vendors is working on groupbuy for a BBK. Check the GB forum.
    Widebody B5 S4
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    I agree if you must choose between the two bbk's you listed, go with the stoptechs 100%... if you must choose a BBK in general Stasis Alcons are the way to go!
    May 18 2007
    Midwest
    Alcon's are NICE!!! Very pricey, though. I can get both the Porsche and Stoptech for $2000.
    Veteran Member Three Rings bandit's Avatar
    Feb 18 2006
    Roundhouseville
    my buddy had problems with his stoptechs. Had to replace a caliper and some other bs.
    Enjoy yo self
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Get an exhaust! Free that sucker up!
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Quote Originally Posted by AddICTioN View Post
    I haven't heard anything negative about the ECS BBK. I'm also in the market for a kit and was seriously considering the ECS setup. As for the rotors cracking, I'm guessing the cross drilled setups are the ones that are cracking? I've never heard about a slotted setup cracking.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    if tracking stoptech is the only way to go!
    Dec 06 2007
    Houston, TX
    I was searching around and read about the rotors cracking. Not sure if it was here or over at AW. Do a search for BBK's on AW and there should be lots of info.
    Widebody B5 S4
