Results 1 to 8 of 8
    Established Member Two Rings killer8424's Avatar
    Jun 12 2008
    02 B6 A4
    Is my car lowered right??
    Hello all,
    I have an 02 A4 1.8 that was lowered before I bought it. I recently pulled off all the tires to paint my calipers and got a chance to look at what had been done to the suspension. The car has Intrax lowering springs with the stock sport struts. I have read through a lot of the posts about the do's and don'ts of lowering, and the general consensus seems to be that this is a big don't. I have had the car for 2 years, however, and haven't seen any change in ride or handling, so I'm wondering if everything is ok. I'm not sure exactly what distance it has been lowered, but if I had to guess I would say about 1.5" in the front, and 2-2.5" in the rear (the front tires ride just below the edge of the fender, while the rears ride just above the edge)s. This seems like an unconventional way to lower it, but the bottom of the car is level with the ground and the owner before me purchased the car used from a dealer as it is now, so I am inclined to think that is ok. So, my questions are:
    -Is it lowered to an appropriate height?
    -Should I replace the stock struts?
    -Are the Intrax springs considered "good" for my car?
    -If I were to upgrade to coilover shocks, do the coilovers replace the springs as well, or are they in addition (I know that the front tires have the springs around the strut, but the back tires have them separate)
    This is my first post on these forums, so I apologize in advance if it is a repost.
    Mar 27 2005
    The Cold North
    Re: Is my car lowered right??
    Quote Originally Posted by killer8424 View Post
    Yes
    Considered Fair quality. They have a tendency to sag over time.
    yes, coilovers replace both shocks and the springs with a properly matched set
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    CoilOvers... then you can adjust your ride height as well..... Stasis is a good set, and well priced!
    j
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Jun 12 2008
    02 B6 A4
    What is involved in changing the ride height? Is it easy enough to raise the car back up for the winter?
    Jun 05 2008
    Houston, TX
    From what I hear it's easy.... Mine are being shipped as we speak... I think you just jack up the car and twist the 2 nuts up the sleeve.
    PAST:
    Mar 27 2005
    The Cold North
    Quote Originally Posted by JGreen76 View Post
    From what I hear it's easy.... .
    On the B6 A4/S4 chassis the rear is a PIA the adjust. The front is a oeice of cake. KW makes the easiest to adjust rear coilover setup for the B6 cars.
    2020 Chevy AEV ZR2
    Jun 12 2008
    02 B6 A4
    Great, thanks for the help. What about the height that my car is lowered to? Does it make sense that the back is lower than the front?
    Active Member Two Rings SunnyG's Avatar
    Jun 15 2008
    DC
    Yes, I just installed KW coilovers. Just pop off the wheels and you can adjust the heights. You'll get about 1/8 rotation in rears at a time and about 1/2 rotation a time forward.
    They are pretty smooth to adj so pretty happy with them.
