    Nov 13 2005
    Colorado Springs
    Omori 52mm boost gauge in B5 S4 Vent - $125 OBO
    I put the gauge in a vent so it looks kind of like the AWE vent gauge only bigger. Also comes with black plexi-glass backer if you like that installation better.
    Edit: I powered it up and took a picture with it lit up (see 3rd pic below). The top right is not as bright as the bottom left. There must be two bulbs inside. I think the top right bulb is loose or burned out. The bulb is not replaceable. Sorry I didn't notice this earlier.
    Nov 13 2005
    Colorado Springs
    Re: Omori 52mm boost gauge in B5 S4 Vent - $125 OBO
    bump - make me an offer.
    Senior Member Two Rings 215 Motoring's Avatar
    Oct 13 2007
    01 S4 Stg3 Bound, 05 R1
    The 215 & 302
    pm sent
    Registered Member Two Rings drewwynn's Avatar
    Jun 03 2008
    01.5 S4 Avant
    Michiana
    does it come with all required hardware for mounting?
    Nogaro S4 Avant 6-Speed
    Stage 3-
    K04s, GIAC Stage 3- Tune, 5 Bar FPR, Samco TBB, 710ns
    Nov 13 2005
    Colorado Springs
    Quote Originally Posted by drewwynn View Post
    Yeah - If you have a B5 S4 then the vent just pops in place of your old vent. Of course, you'll need to route vac hose and backlight wires. You prob want to add a no-buzz fitting from ECS or PureMS.
