Results 1 to 40 of 47
    Saint Cloud, Fl
    Add me to the other list :) ......
    Had to mess with Shawn ! I finally took his advice and got a real "Big Turbo Setup"
    Construction begins tomorrow. Wish me luck.
    -GT2871R Eliminator
    -ATP High Flow Manifold
    -Eurocode Test Pipe
    -ATP 3" Inlet Pipe
    -Genesis 550cc Injectors
    I also took pictures of the new and old ATP Manifold, you can see the difference in the 2
    The new V2 version is hella heavier than the old and now has ribs for strength
    instagram ------------> low_enforcement
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    Re: Add me to the other list :) ......
    that is really big
    BetaAlphaTau member #19
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by 20vturbo View Post
    that is really big
    thats what my wife said to me too
    ive been trying to get a used APR mani, but i guess ill be trying a new ATP mani as well... it does look better... how is that 3" TIP compare to winston's metal TIP i wonder?
    APR Stage 2/AWE Intake
    Saint Cloud, Fl
    Quote Originally Posted by Papachristou View Post
    Im not sure yet, but I know that it's hella cheaper
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Reason for going with the 2871r versus a GTRS?
    What are your plans with the old version ATP manifold?
    -Sami-
    Veteran Member Three Rings A4p's Avatar
    Mar 06 2006
    Audi 1.8TQM6 S-line USP 2004
    Sweden
    hope everything goes well GL
    oh remember DV exhaust FMIC CLUTCH :)
    USP CLUB MEMBER 861
    Rev0 stage I file - 300+ bosch injector - OFE SS - APR Snub mount - Nitrogen - RS4 Swaybar - K&N air filter - **-
    Nov 24 2004
    MOntreal
    she was prob talking about your belly
    Saint Cloud, Fl
    I got a good deal on the turbo and it only kicks in a few hundred RPM later, hopefully that will aid me in staying on the boost too much.
    Buncha motorcycles
    Memphis, TN
    haha, good try, im shredded... i run everyday! but ur brunette did enjoy doing her laundry on my abs
    let me know if u wanna come off that stuff... APR is just too proud of their software ive emailed andy twice and he wont send anything back...
    Nov 24 2004
    MOntreal
    I spoke with Andy and it' 150$ for a software transfer....
    I do her laundry every day so that I don't have to run
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    You're running a 71r eliminator, correct? A 2871r is a bit different.
    Some fast things and some slow things
    ~Josh~
    Veteran Member Three Rings orangelmo's Avatar
    Jul 05 2007
    Stouffville
    Do you have to buil up your engine at all to run a 71r elminator?
    Oct 31 2005
    Virginia
    ^^I had a 71r for about a year with no problems on a stock motor.
    ~Josh~
    Saint Cloud, Fl
    Quote Originally Posted by mtbrider View Post
    oops, edited
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    ^ im glad you bought that from dave and i stoped being so tempted to buy it haha. congrats.
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Saint Cloud, Fl
    well I begin the install tomorrow after I get off at 6am
    Buncha motorcycles
    Memphis, TN
    ill bet u cant wait! id be working all day on some red bulls to get er done!
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    I'm so jealous.... damn BT show offs
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Saint Cloud, Fl
    yah Im hoping that it should take me no more than 10hrs tops. Any suggestions would be welcome from all
    Veteran Member Four Rings yoogene83's Avatar
    Apr 27 2004
    2017 Pacifica Limited / 2014 BMW M5
    Seoul
    that ATP mani is a motherfucking bitch. that will probably take you a good chunk of time
    Saint Cloud, Fl
    I baught one of the swivel sockets. Everyone says that they should make the job alot easier.
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by 7speed View Post
    Righty tighty, lefty loosey.....
    Make sure to post up some speedo vids!
    -Sami-
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    unless you run into some kind of problem it should take way less than 10 hours. If you know what you are doing (what to take off and replace without having to look aimlessly at the car) then you could relistically take the stock turbo and manifold out as well as the cat then swap in a test pipe or high flow cat with the new turbo and mani in less than 5 hours. The bolts holding the cat to the exhaust might be a pain since they are probably rusted so be sure to get 3 new bolts and nuts for that.
    Then don't forget to put the back bolt through the manifold (of the 3 that hold the turbo) before bolting it to the head because you cant slide it through after the mani is installed since it is up under the head.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Saint Cloud, Fl
    Now I just need to buy some coolant and oil for the change
    May 24 2007
    Southern California
    yes and yes.
    Quote Originally Posted by yoogene83 View Post
    Kyle
    2.0L Revo GTRS Eliminator
    Saint Cloud, Fl
    Change of Plans, construction will begin after a short nap
    Oct 31 2005
    Virginia
    haha, good luck with everything
    ~Josh~
    Dec 03 2005
    2 pedals 1FG
    connecticut
    My 2871R (full T25 flange) arrives next week. Its at ASP getting 'tweaked' right now.
    -Doug
    Buncha motorcycles
    Memphis, TN
    what are they doing to it?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Custom machined compressor inlet and EBC/N75 boost port tap on compressor housing.
    The stock (cast) compressor inlet is stepped and not smooth on the inside. ASP cuts it off and CNC machines a solid, one-piece, inlet. This way the ID of the compressor inlet is the same the whole way in. In theory, it reduces turbulence. My GT28RS was like that and this modification is part of the ASP GT28RS kit.
    This is what it looks like (on my old GT28RS):
    -Doug
    Jun 30 2007
    Raleigh, NC
    GET RID OF THAT TIP! if i'm not mistaken that's the one where the screw comes out and destroys your turbo... it's already claimed a few, please don't be the next.
    amen.
    probably won't help as much as it should.... just make a wrench, or get a 12mm crow's foot w/as small a drive as you can find... then take a bench grinder to it.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    good luck on the install sam cant wait to get another ride to see the differance!
    then ill prob have to get a USP and do a 2871R
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Buncha motorcycles
    Memphis, TN
    is that a gt2871r elim? what greg runs?
    im trying to decide on coughing up $4700 + test pipe for APR 3+ or piecing together my own kit with
    ATP mani
    gt28rs or gt2871r elim (difference?)
    AN lines
    test pipe
    revo with sps 3
    Apr 24 2005
    E55 AMG, CTS-V
    Im gonna school you real quick and hopefully others will catch on. First off no it's not the same as what Greg runs. Greg runs a 71r Eliminator not a GT2871r. Then a GTRS is NOT a GT2860RS which others seem to think all the time.
    The GTRS and the 71r Eliminator turbos are the same exact compressor and turbine housings which are BOTH SMALLER (as in both turbos and both housings) than the GT2871r and the GT2860RS. The center section which has the wheels (turbo blades) is the same, but like I said the housings are smaller. This means the inlet for the turbo is smaller and the casing for air to flow through is smaller and the exhaust inlet is much smaller (where the air comes in from the manifold to spin the turbo). The GTRS and 71r Eliminator turbos have a tiny K03 flange (same as the stock turbo) unlike these others that have a much bigger T3 or T25 flange to spool up the turbo, and like I said before the exhaust housing is a custom cast piece from ATP made with that K03 flange so it can bolt to the stock manifold and this turbine housing aka hotside of the turbo is smaller.
    Footnotes: 71r Eliminator is not a GT2871r, it is smaller.
    GTRS is not a GT2860RS, it is smaller.
    ~David~
    CTS-V 9.6@148
    Buncha motorcycles
    Memphis, TN
    lol, thanks...
    i think im just going to piece together my own kit...
    Atp mani is $300 (eurocode)
    Gt28rs-$1000 (online vendor)
    winston metal TIP $350 i think
    AN line kit $300-400 (eurocode)
    Gensis 550 injectors and adaptors $420 (eurocode)
    spark plugs and some gaskets $100 approx
    REVO software $700 + used sps3 hopefully $200
    test pipe 3" $150
    $3600 round about
    am i missing anything?
    Nov 24 2004
    MOntreal
    lol, thanks...
    test pipe 3" $150
    $3600 round about
    you can have my apr for less I will pay for the software transfer from apr
    Buncha motorcycles
    Memphis, TN
    yeah I know or I can have all new hardware plus I just drive my car once or twice a week now! plus I'd have adjustability with REVO
    apr will cut me a good deal too b/c they want a demo in memphis...
    Saint Cloud, Fl
    will hopefully have this finished Saturday. The damn O2 sensor was stuck in my other manifold. I tried everything to get it out
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    PB Blaster
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by 400HPA4 View Post
    PB Blaster
    Deffinately!
