Results 1 to 8 of 8
    Veteran Member Three Rings dgrs4sd's Avatar
    May 25 2008
    So Cal
    ebay tail light issue
    ok B5 A4 guys, I have a ? for you
    I have a 2001.5 S4 with black tail lights which I wanted to swap out for the OE look
    I bought a pair on Ebay and the bulb mounting pattern in the rear does not fit
    my question is what is the difference between the 96-98 vs the later models, could these blacked out lights be the earlier style and if I bought that style from the same seller would they work?
    here is a pic of the lights, mine are on the right, the ebay ones on the LEFT:
    thanks in advance for your insight and help
    Veteran Member Four Rings TMorris's Avatar
    Jul 09 2007
    B5
    Charlotte/Columbia
    Re: ebay tail light issue
    you mean yours are on the left?
    check this out
    http://ctny.audiworld.com/mark/a4/diff/
    Shows you the diff in the tails. There are actually 3 diff styles that were oem and you are going to want 99.5+
    May 25 2008
    So Cal
    no mine are on the right, the are the dark style.... the ebay ones are on the left
    Jul 09 2007
    B5
    Charlotte/Columbia
    well in that case it seems you have the old tails. You need the newer style wiring harness.
    Why does your car have old style tails if you have an S4
    May 25 2008
    So Cal
    i think it is because the guy who owned the car before me wanted the dark lights and converted the car to accept those
    are you sure this is the old style mounting pattern for the bulbs? If so I will swap with the vendor and be very happy!
    Veteran Member Four Rings 1 ate T's Avatar
    VW Jetta GT, 01 Eclipse GS
    Newark,OH
    Show the front.
    2000 A4 1.8TQM - Sold
    Will be back in an Audi this summer!
    Jul 09 2007
    B5
    Charlotte/Columbia
    this is what the new style wiring is like
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Your black lights have the old style bulb pattern, like the 96, 97 A4's have.
