Results 1 to 8 of 8
    Registered Member Two Rings WhiteVenomA4's Avatar
    May 23 2008
    B7 Audi A4 '08 S-Line Ibis
    Los Angeles, CA
    S6 L.E.D. Daytime Lights on a B7 A4..
    I really like the beasty appearance they give. After only seeing 2 photo's. Please Post more pics, if you have any.
    Q:Does anyone know how these will look with only halogen lights combo?
    They seem a bit pricey anyone have better pricing than $400+?
    Ignore the price for a second and tell me what your opinion is for these lights Overall.
    Pic of Product & Details:
    One of arguably the most distinctive visual accent ever to come out for any European vehicle. Total of (10) L.E.D. lights (5 per side) can be wired in place of standard headlight Daytime Running Lights. We recommend using the S-6 bumper with factory provisions for the LEDs, but with some creativity and patience (or a reputable body shop), the standard A6 or S-Line bumpers can be modified to allow fitment of the LEDs. Electrical connector housings and wire inserts included. (20"Length X 3"Width X 5.5" Depth)
    '08 A4 2.0T SLine
    White on Black. 15% Tint All Around.
    5% SUN STRIP
    Quad Muffler/Tips MagnaFlow Exhaust + Custom Piping. (Including RES. DELETE)
    (Work in Progress)
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Re: S6 L.E.D. Daytime Lights on a B7 A4..
    vagparts should have them for around 300. unfortunately its not a simple job to fit them
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Nov 05 2007
    Oregon
    Working on this now for our A4, unfortunately it's a slow project, won't have pics for a while. Not easy fitting in an A4, but possible. Won't look as good though with halogens though because the lights definitely have a light blue cast.
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    the lights are easy to mount once your willing to cut into your bumper, its really up to you how you want to mount it, you can use screws and carefully drill into the light housing at an angle so you dont end up inside where the LED's are or so the butt of your screws arent visible. the hardest part is creating the grille and in my case figuring out how i want to wire it since i dont have the DRLs. mine will be done shortly as the grilles are being created now, fogs are already on the bumper and im still trying to figure out if i want to have them with the fog light switch or run an independant switch so they are on when i please. pics in a few weeks
    overall definately a really good project, takes some time and patience but worth it
    Mar 19 2008
    slim, where are you getting yours done or are you taking this task up yourself?
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    do i hear DIY??
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Mar 19 2008
    id log a diy for them if i had a set of the led's to compare to the bumper to see exactly what i gotta work with. i really want to see them on another a4 before i go nuts.
    2019 S5 BO.SS
    2009 R8 6 Volt :)
