Results 1 to 8 of 8
    Veteran Member Three Rings dgrs4sd's Avatar
    May 25 2008
    So Cal
    lower engine cover missing need one...help
    i recently bought a 2001.5 S4 w/ full RS4 body conversion,
    my issue is that the lower engine cover/valance, not sure what you call it but the thing you take off BEFORE an oil change
    my car does not have it and I am wondering if it is because the RS4 bumper sticks out more and I need a euro one or if the regular S4 one will work
    this is causing the bumper to sway in the wind if you will when I drive...
    any advice would be greatly appreciated
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: lower engine cover missing need one...help
    The belly pan? No prob. I've never had one. Makes oil changes easy.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    If their was a poll of how many people still have em, it would prob say 15%
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    its better not to have one sometimes just to see if your leaking. i took mine off and noticed some power steering on the ground . you can buy it at the dealer if u want one, im sure it wound fit that rs4 bumper with a little modification
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    its fits with no modification. If your bumper is swaying because of it then i woudl say put it but in, you dont want it to crack. Some people over AW did and invegtigation regarding the belly pan. They said that its there because it helps keep engine temps down by direction the airflow some how. The test came backl pretty good, With the bely pan in engine temps where lower than with it off. Not sure how it happened bu thats what they got. ANyways, I still dont think its anything to worry about.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    It is nice to have in the winter, keep some of the salt out of the engine bay depending on where you are from.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    May 25 2008
    So Cal
    well for me that is not a worry, I live in San Diego, I guess I think it would cut down on some road noise too as well as complete the anal retentiveness within myself...
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    The regular A4 / S4 engine undercover does NOT fit the RS4 bumper at all.
    The flexing is not due to the missing cover - make sure the bumper lower support struts were fitted during the conversion.
    The lower sides will flex / move otherwise.
