Tonight Justin and I did some fine tuning and adjusted the timing and boost. We set it for about 20-21 psi and set timing from -8 degrees to -7.25. (Tuning was originally set for 93, and our piss 91 had audible ping with anything over -7 degrees) We did pulls in 3rd gear to get an idea, and it was very smooth and the logs looked ok.
After leaving his house, I wanted to feel the power in 4th on the freeway and pulled from 4,000 rpm to 7,000 and it was strong and consistent throughout the rpm range.
After arriving at home, a buddy wanted a ride so I did 2nd and 3rd gear pulls and during both pulls the power arrived late at 5,500 rpm. The turbos spool normally but boost does not hit until approx 5,500. Say you are in 3rd at 3,000 rpm and push it, the turbos spin and you prepare to start moving, but the car acts as if it is in limp mode and when it hits mid 5k rpm, boom there is the power. I tried this also in 4th, and the same thing happened, gutless in any rpm until 5-6k then crap load of power.
I vagged my car and were 0 codes. I do not have the logs, but from looking at the last ones we got, it looked fine. I have not taken logs now as I do not have his computer. Hopefully someone has shared this same experience and can lead me to a fix.
Thanks
