Results 1 to 6 of 6
    Senior Member Two Rings Tfreestyle's Avatar
    Dec 07 2006
    00 Audi S4, 86 grand national
    Los Angeles, Cali
    finally got access to a vag tool that works
    never could get the ebay cable to work so a buddy helped me out, heres what came up...
    VAG-COM Version: Release 607.3-UD
    Friday,06,June,2008,14:39:05
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine
    Part No: 8D0 907 551 M
    Component: 2.7l V6/5VT G02 0002
    Coding: 06711
    Shop #: WSC 81784
    5 Faults Found:
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    P1649 - 35-00 - -
    17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
    P1454 - 35-00 - -
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-00 - -
    17870 - Exhaust Gas Temp Regulation for Bank 2: Implausible Signal
    P1462 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 08: Auto HVAC
    Part No: 8D0 820 043 P
    Component: A4 KLIMAAUTOMAT D57
    Coding: 00160
    Shop #: WSC 06325
    No fault code found.
    Address 15: Airbags
    Part No: 8D0 959 655 G
    Component: Airbag Front+Kopf 1002
    Coding: 00304
    Shop #: WSC 06325
    Address 17: Instruments
    Part No: 8D0 920 980 D
    Component: B5-KOMBIINSTR. VDO D11
    Coding: 02264
    Shop #: WSC 00000
    Address 35: Centr. Locks
    Part No: 8L0 862 257 N
    Component: CV-Pump D11
    Coding: 16140
    Shop #: WSC 06325
    7 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    00991 - Interior Lights
    28-00 - Short to Plus
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    Address 45: Inter. Monitor
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06325
    1 Fault Found:
    01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
    35-00 - -
    Address 55: Xenon Range
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00012
    Shop #: WSC 06325
    Address 56: Radio
    Part No: 8D0 035 195 A
    Component: Radio D00
    Coding: 00115
    Shop #: WSC 06325
    End --------------------------------------------------------------------------------------------------
    1986 Buick Grand National, 109 block, 30 over, forged internals, T70 and all the extras. will be seeing a 10sec pass soon.
    1984 VW Vanagon Westfalia project
    1974 Mercedes 450sl
    1970 Chevy El Camino 454
    2004 Escalade EXT
    (Just Sold) 2000 S4 sedan 6spd Stage 3
    Established Member Two Rings DAP's Avatar
    Mar 16 2004
    Re: finally got access to a vag tool that works
    Bad EGT sensors, incorrectly coded instrument cluster, crappy tune...
    Apr 05 2007
    def. bad EGT sensors.
    Dec 07 2006
    Los Angeles, Cali
    why do you say its a crappy tune?
    1974 Mercedes 450sl
    2004 Escalade EXT
    Dec 06 2007
    Calgary, AB, Canada
    The boost maps are either a little funky, or you have a serious boost leak somewhere.
    Dec 07 2006
    Los Angeles, Cali
    probably have a boost leak. going to check it out this weekend when I get some free time and make a new boost leak checker.
    1974 Mercedes 450sl
    2004 Escalade EXT
