Results 1 to 13 of 13
Thread: I'm Leakin?
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    I'm Leakin?
    Ok, normal vacuum is 19 -21 in/Hg, I'm getting 10-12 95% of th time, and occasionally get a normal reading. My boost spikes at 12psi and holds at 10. (stock program) Can I have a vacuum leak without having a boost leak? and where could that happen?
    -Ryan
    2002 1.8t Quattro
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Re: I'm Leakin?
    Air conditioning, electric stuff, etc, could all contribute to low vacuum.
    Do you have audio or anything stressing your alternator out?
    ÖMGHI2Ü
    Photography
    Apr 06 2007
    Pittsburgh
    Re: I'm Leakin?
    nope even with everything shut off I gat 10 in/Hg of vacuum. Any other ideas?
    -Ryan
    2002 1.8t Quattro
    Veteran Member Three Rings TurboQuattroPwr's Avatar
    Sep 28 2006
    Delaware
    Re: I'm Leakin?
    That's what she said.....
    2018 Audi S4 3.0T
    18% Tint, CquartzPro Ceramic Coating
    2002 Audi A4 1.8TQM *Gone*
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: I'm Leakin?
    Check all your connections, check valves, suction jet pump, check your vacuum lines for worn spots...GL
    Dec 06 2007
    Re: I'm Leakin?
    i have the same prob all i know is i have a bad 02 sensor, i don't know if that would contribute!
    -Kirk
    BetaAlphaTau Member #58
    Apr 06 2007
    Pittsburgh
    Re: I'm Leakin?
    Quote Originally Posted by TurboQuattroPwr View Post
    that couldn't be more perfectly used.
    -Ryan
    2002 1.8t Quattro
    Dec 06 2007
    Re: I'm Leakin?
    bumpo we need to figure this out!
    -Kirk
    Apr 06 2007
    Pittsburgh
    Re: I'm Leakin?
    well I've checked all my tubes and nothing seems worn, the only thing is that my coolant flange is leaking. but I don't think that would have anything to do with vacuum.
    -Ryan
    2002 1.8t Quattro
    Buncha motorcycles
    Memphis, TN
    Re: I'm Leakin?
    checked your DV?
    APR Stage 2/AWE Intake
    Apr 06 2007
    Pittsburgh
    Re: I'm Leakin?
    no I didn't does the stock one have issues?
    -Ryan
    2002 1.8t Quattro
    Dec 06 2007
    Re: I'm Leakin?
    i have the same issue and i've changed my DV and N75 no luck!
    -Kirk
    Jun 08 2008
    Calgary AB Canada
    Re: I'm Leakin?
    huge bump...
    What are the stock readings for vacuum and boost?
    Im getting 15inHg and at idle, spiking 14lbs and holding 10lbs.
    Should i be hitting higher?
