Results 1 to 12 of 12
    DUH! an Audi
    los angeles, CA
    how do to remove this tray on the dash...
    here is a pic of the tray, borrowed from a user on AZ...how do i remove this?
    thanks!
    Active Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    Re: how do to remove this tray on the dash...
    just yank really hard lol
    whatcha doin Randy?
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    DUH! an Audi
    los angeles, CA
    umm replacing it with the ones with chrome nothing fancy haha
    cant yank that...will break it
    DUH! an Audi
    los angeles, CA
    anyone? need to know by tomorrow =x
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    In order to remove mine so as to put the Defi Unit, i removed the RCD below it as well...Otherwise I couldnt pull it out...
    I dont know if there is another way, but that is the way I worked it out...
    Rear Valence+Trunk Air Lip+Mirror Housings+WindowTrim CF'ed, Debadged Trunk, Front+Rear Red Tie Hooks, Engine Cover Removed, Painted WasherFluid+Coolant caps, Toyo Proxes Racing Semislick R888 225.40 (for now), OZ Ultraleggera 8x18 ET45 Black, 76mm Custom Cat-Back Exhaust, OEM BlackMask w/ black Audi Badge, Sparco 33mm Racing SteeringWheel, RUF Snap-off WheelHub, CF ShiftKnob, ColourMatched BrakeCalipers, APex-I TurboTimer black, Custom BilsteinPSS Coils, Tinted Tailights, GReddy Electronic Φ=60 Warning A/F, WaterTemp, OilPress, FuelPress
    Defi BFSeries (w/ link) Φ=60, Boost, EGT, OilTemp, + 1, Custom GaugePods by XM Greece, PIAA CityLights Super White and White, Sparco CF Pedals, Simoni Racing SteeringWheel CronoMeter
    DUH! an Audi
    los angeles, CA
    RCD? radio? or the piece above the buttons...
    does it just pull out?
    Jun 02 2008
    Greece
    In my car, underneath the dashes, is the RCD unit, which comes out in one piece and then you can pull the dash from underneath...
    Let me show you some pics...
    Hope I helped a lil bit...
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    1) You have to remove the black trim piece above the radio
    2) You have to pull the radio out a bit to clear the bottom of the tray
    3) Using a small Robertson screwdriver you push down on two tabs on either side of the tray that lock in in place and then pull out the tray
    DUH! an Audi
    los angeles, CA
    thank you guys, sucks we gotta remove the radio... is this truly necessary?
    ill give it a shot tomorrow
    thanks again.
    Jun 11 2005
    Vancouver, BC
    You don't need to pull out the radio for the extra clearance but it does help with removing the tray.
    Otherwise the bottom of the tray will touch the top trim of the radio and if you pull it out the wrong way it will screw up the outer edge of your radio trim unless you get a bit creative.
    I was unable to remove my cupholder without pulling out the radio 2"
    Jun 02 2008
    Greece
    I cannot tell you nothing more on nothing less from what we did to my car...
    If someones knows better, it' ll be good to say it so as to save you from trouble...
    However if anything, tell me to help you anyway I can...
    Happy moding
    Jun 11 2005
    Vancouver, BC
    Look at the pics of my cupholder in this thread and you see the tabs I am talkng about: http://www.audizine.com/forum/showthread.php?t=195375
    When you look at the bottom of the tray you will see the long center piece which prevents the tray from pulling out smoothly.
