Results 1 to 16 of 16
    Senior Member Three Rings Insomniac's Avatar
    Jun 03 2008
    Hershey
    Lake County CCS 6.5in Pad Kit worth it?
    Hey fellas
    I will be picking up a porter cable 7336 soon, and I was wondering about the different pads to get for it. I'm looking on Detailer's Domain and am curious if you think the 6.5inch pad kit is worth the money or not. Am I really going to use all 6 different types of pads? My other thought was to just pick up a black,white, and orange pad (~$33).
    I will be using Adam's revive polish, swirl & haze, buttery wax. Three different products, which is why I thought why not just three different pads. Thanks in advance!
    free earl
    Veteran Member Four Rings Grouse's Avatar
    Sep 06 2005
    05 a4 3.0 Ultrasport
    Norwalk CT
    Re: Lake County CCS 6.5in Pad Kit worth it?
    Get
    4 orange,
    4 green
    4 white
    2 black
    It is difficult to spur them clean with the PC. so get 1 pad for each 1/4 of the car. The exception being the black wax pad.
    In general i will used 2-3 pads per half car.
    USPClub Member # 32
    Nominated best detailer in western washington
    Chosen as one of the top 9 detailers in the US by autoweek.
    Veteran Member Three Rings Twista616's Avatar
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    Quote Originally Posted by Grouse View Post
    Get
    4 orange,
    4 green
    4 white
    2 black
    Right on the money! The most common pads used are the orange and white. You absolutly need those pads if any. Black and Blue are finishing pads, so you may want one or two, but you don't need them. Just nice to have...thats all.
    "I'm right 60% of the time, all the time!"
    2005 A4 QT-SOLD // 2006 A4 QT-SOLD
    '14 SQ5 | Ibis White | 21" Stockies | More goodies in the works
    Insta: @imgarretthess Tweetness: @imgarretthess
    Dec 19 2007
    York, PA
    to answer your question, yes, its worth it.
    Jun 03 2008
    Hershey
    Quote Originally Posted by n7plus1 View Post
    to ask your question, yes, its worth it.
    you didn't ask it though, you answered it!
    Thanks for the advice.
    free earl
    Senior Member Two Rings reggaemylitis's Avatar
    Apr 19 2008
    06 A4 Avant 2.0TQM
    South Lake Tahoe, CA
    Get
    4 orange,
    4 green
    4 white
    2 black
    You go through 4 orange and 4 white for every car you polish?
    I had no idea I would need that many! I thought buying an extra two might be overkill. Can you at least reuse them? And what do you mean by "spur them clean?"
    Thanks for the help. I am about to do my first polish job soon, and want to be as informed as possible!
    APR Stage II. AWE Exhaust. AWE FMIC. Forge DV. JHM Short Shifter. RS4 Rear Sway. 034 Turbo Inlet Hose.
    "We're going to sodomize our vast imaginations with this pornography!" -Ignignokt
    Jun 03 2008
    Hershey
    Yeah, that seems like a lot of pads for a detail. But I have no clue, and I'd like to be informed as well!
    free earl
    Senior Member Two Rings Dark 'n' Dirty's Avatar
    Sep 16 2006
    Newton, MA
    Can you fill us in on what exactly you'll be doing? Paint correction, maintenance, etc.? I saw the list of materials you'll be using, being swirl & haze, revive and butter wax, and if you're going to be doing more paint correction than maintenance, I would invest more money in better product than pads. Pads definitely make a difference, but you want the correct combination of pad and product.
    May 13 2007
    Northern VA
    I would go with 5.5" pads instead of 6.5". Id also say blue and gray pads are important if you want to go after maximum gloss.
    - Dan
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    Quote Originally Posted by reggaemylitis View Post
    Everyone is different on how they do thing. Grouse knows what hes doing, so if 4 pads work for him, run with it! I use 2-3...and for correction, 4 or more! Its easier to pull a pad off and stick a new one on, rather than having to clean it, and put it back on. Time is money...for some of us! You can reuse all the pads, if cleaned well after each usage, they can last for some time!
    Spur it clean means to clean the pad...usually done while the pad is on the machine, spinning then, you take a brush or a spur and press it against the pad. Thats the quick way of cleaning...if you only have a couple pads and not alot of time.
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 24 2004
    Just so you all know when ordering up pads you don't have to get the kit in the description.
    You can request for 3 white or 3 orange etc...
    as long as you get 6 you are good to go.
    Jun 03 2008
    Hershey
    Quote Originally Posted by Dark 'n' Dirty View Post
    Well I will be doing a little correction and then maintenance on my car. But I would like pads for everything so I can do other cars as well. You say better product (polish/wax etc.) What would you suggest?
    free earl
    Feb 24 2004
    I would go with
    1 yellow
    3 orange
    or 3 green
    3 white
    1 black
    1 blue
    Dec 19 2007
    York, PA
    Quote Originally Posted by Insomniac View Post
    lol...oops..good catch..changed!
    Jun 03 2008
    Hershey
    Quote Originally Posted by phil@detailersdomain View Post
    I would go with
    1 yellow
    3 orange
    or 3 green
    3 white
    1 black
    1 blue
    Have that in a bundle I could get? haha
    Still wondering which waxes/polish to get for use with my new porter cable
    free earl
    Feb 24 2004
    yes order the kit and in the notes let us know what combo of 6 you want.
