Yeah,
I have been dealing with this issue since last October when I finally put on my AWE fueling kit. ( I had the K04's on there already from a trans job I did prior) I have a nogaro blue 01 S4 avant with blue alcantara. It has been K04'ed with DP's etc. I thought I had a leak in the intake system somewhere but I can't find it.
I also get bucking, hesitation at slight throttle when I am in more than 10HG vacuum. ( 10-20 ) It is noticeably worse in warmer weather. It seems better when I reset the CEL light with the VAG com. The codes i routinely get are fuel trim to rich and fuel trim to lean on bank 1 and bank 2. They come back every time. I can't inspect the car, it never gets its readiness codes.
I changed the plugs, no better. I swapped the MAF, Ignition stages, replaced the front two O2 sensors with new OEM (with plug etc) Bosch units. I swapped the throttle body, swapped a buddy's ECU in with no tuning..... All stays the same always. I swapped DV's, replaced the Coolant Temp sensor still no better. I am def gonna try the air Grid straightener on the MAF that was mentioned earlier up in this thread. I have not once gotten any misfire codes?????? How weird is that. I also played all around with the injector orientation and that didn't change a thing either. The thing with my car is it almost too violent to drive sometimes when it is hotter outside. And the gas mileage is like 16mpg right now. I can't even get 200 miles to a tank, so it just sits there while my brembo 14 inch brakes get rusty and are now shaking and pulsing. Damn it!!
The only thing I still have to do is to replace the driver side lower intercooler pipe. When I smoked out the intake to check for leaks, I saw some smoke come from the weld where the mounting bracket is that holds it to the upper part of the oil pan. That just doesn't seem like a big enough leak to cause this problem. But I do have the pipe and I am going to change it.
Has anyone else made any headway on their issues?
Just for side fun, I had to replace the Alternator the other day too!! I just want to drive this car...
