Results 1 to 4 of 4
    Oct 28 2007
    j-ville
    I Dunno WHAT else it could be! Water Leak!
    ok ive posted before about water leaking into my 2004 a4. Its on the driver a passenger front carpets and on the over head by the rear view mirror. So i went and checked the drains in front of the firewall under the battery area and the sunroof drains, all are good! Now on the passanger side it looks like the water is running down inside the piller along the windshield and passenger window, bc i can see it drip past the small crack where the pillar meets the dashboard. then it continues down to the floor. Is there any other drains i could be missing? is there anything else that could cause this!!! help!!
    Active Member Three Rings 3thrd_a_4's Avatar
    Oct 15 2006
    03 BT A4/91 GTI 2.9VR6 S/C'd
    Re: I Dunno WHAT else it could be! Water Leak!
    leaky windshield. Has it ever been replaced?
    ReVO BT and a bunch of other stuff
    Oct 28 2007
    j-ville
    yes its been replaced, but some guy re sealed it the other day along the sides, i dunno he said the top strip was fine but it doesnt look right to me. but if said it was good, hes the expert
    Buncha motorcycles
    Memphis, TN
    well if its leaking above the mirror, the windshield seal is obviously the culprit... he needs to take it out and reseal it, you cant just add sealant from the outside
    APR Stage 2/AWE Intake
