Results 1 to 8 of 8
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    Codes p2008 p2015
    Anyone have an idea what these codes are:
    p2008 and p2015, it says some sort of intake manifold open/closed?
    Is this just a TB realignment?
    Its a 2005.5 2.0T
    Senior Member Two Rings Eweezy27's Avatar
    Oct 01 2007
    Ashburn VA
    Re: Codes p2008 p2015
    I'm getting these same codes. Does anyone know what they pertain to?
    Mar 24 2007
    Intake manifold flap
    Oct 01 2007
    Ashburn VA
    Thanks but could you shed some more light on this for me?
    What needs to be done or replaced?
    Mar 24 2007
    IDK, the dealer took care of it
    Established Member Two Rings Asimko's Avatar
    Apr 26 2008
    I just had my car at the dealer for the same thing. Apparently this is a pretty common issue and they first try to fix it with a software update. If the update does not work they replace the intake flap motor. I had my intake flap motor replaced and it was back to normal for a day but now I'm back to square one. The symptoms were/are CEL, bad gas mileage and cold start problems.
    Oct 01 2007
    Ashburn VA
    Quote Originally Posted by Asimko View Post
    My car is not under warranty anymore so this looks like it will be out of pocked for me.
    Will getting a software update affect my GIAC software?
    Established Member Two Rings remOOOO's Avatar
    Jul 10 2008
    A4/B7 Avant 2.0T Quattro
    Naples FL
    so is there any update about this junk? my a4 2.0t had reflashed ECU because of that and MIL is back... Is there a DIY somewhere or can anyone guide me thru it?? the only Audi Dealership around is Audi of Va Beach and they are biggest thiefs on earth. They wanted $90+ tax for Cam Follower I can't even imagine how much they will charge me for that fix.. I've found part number for that motor its : 06F133482D this online shop has it for $220 https://www.trademotion.com/partloca...er1=06F133482B
    also that tsb : http://www.goapr.com/images/support/...intake_tsb.pdf
    ANYONE ???
