Results 1 to 8 of 8
    Mar 18 2008
    Grande Prairie
    Unhappy Help a noob ID a part
    I was poking around my engine bay and I found a loose part I can't easily identify. I have the part number but my googling has been fruitless so far. I was hoping someone with a part list or bentley manual could tell me what it is and where it goes.
    It looks to me to be some sort of cover - translucent white, semi-tubular with two different end diameters.
    PN: 8E0 955 109 >PP< 2
    TIA
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Help a noob ID a part
    picture?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Mar 18 2008
    Grande Prairie
    Here are a few shots.
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Looks like headlight washer pump cover:
    Mar 18 2008
    Grande Prairie
    Aug 26 2005
    Quote Originally Posted by JspotMD View Post
    TIA
    According to ETKA, it is a covering for the headlight washer pump.
    Jun 08 2008
    Calgary AB Canada
    while were on the same topic... anyone want to help me figure this one out?
    Aug 26 2005
    That is the crankcase ventilation pressure regulator valve.
