Results 1 to 18 of 18
    Established Member Two Rings kmoney's Avatar
    May 11 2008
    2000 audi s4
    A4 2.8 B5 compatible with S4 engine?
    i have an audi a4 2.8 b5 and was planning on a summer project of swapping it for a b5 s4 engine and wondering if anyone on here has done this or knows exactly what is needed for this type of project. Ive heard different things that you can use the stock 2.8 tranny, mounts, and gears and some you can't. I'd like to keep my stock tranny and gears. If anyone could give me any help it would be greatly appreciated you can pm me if you want.
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Re: A4 2.8 B5 compatible with S4 engine?
    SEARCH!!!! this was covered last week. and yes it will fit but you will need a whole parts car to make it work right.
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    The short answer is, yes.
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    yes
    Senior Member Two Rings fenderstrat1184's Avatar
    Oct 17 2006
    '00 1.8tqm, '90 jeep cherokee
    northeast
    What's AOA? If Audiworld is the 1960's, AOA is 'the man.' Don't try to fight the man, because, just like the hippies, you'll lose.
    Apr 05 2007
    Bend
    it'll bolt right up, plug and play.lol
    My B5's For Sale PM ME!
    UberFellas
    stanceworks.com
    ^^Superior^^
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    buy the S4 and swap the tags, easier than all that manual work and searching
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Now now all you need is a little Duck tape and JB weld; you'll be runnin in about an afternoon!
    May 11 2008
    2000 audi s4
    i called SSPtuning from Long Island and they said that it pretty much just bolts in place but they charge $1900 for labor, is there any place known in New York or surrounding states that would have a much cheaper price?
    Dec 14 2006
    Halifax, NS, Canada
    For the amount of work needed that is pretty cheap.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by Squarrl View Post
    x2
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by kmoney View Post
    I guarantee you won't find cheaper.
    I have seen this performed twice now, it is a bit of work.
    -18 718 GTS
    Dec 14 2006
    Halifax, NS, Canada
    even at $50 /h labor that is more then 38 hours work me thinks
    NOW DEAD :(
    Senior Member Two Rings safab's Avatar
    Apr 25 2007
    ca
    What are your power goals for changing over to a 2.7t setup? And are you planning on swapping over to an s4 harness/ECU or using a standalone. If your power goals are not too high and your ok w/ using a standalone, you could just bolt up a stock turbo kit from a 2.7t (manifolds/turbos/dp/intake system) and run it that way....exhaust manifolds should bolt right up and you could flip 2.8 intake manifold and use that.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I'll do it for less, but you'd have to bring it to MI.
    May 11 2008
    2000 audi s4
    i think id swap over to the S4 harness/ecu
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    So you're telling me that if you devoted one week of your time, provided you had all the parts, it would take 38hrs? I take it that's flat rate.
    I'll take the 38 hrs as a challenge. From everything I've read about the swaps it really isn't that bad.
    Aug 24 2005
    1999.5 AUDI A4/T/Q/M
    Chicago, IL
    THis topic is posted like twice every 2 weeks by noobs.
    Quote Originally Posted by JaVa View Post
