Results 1 to 17 of 17
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    What do I need? (Headlights)
    I just got some OEM S4 Headlight and was wondering what bulbs, etc. do I need to purchase?
    I have some D1S bulbs/ballasts on the way but there are two other bulbs I need?
    Sorry for sounding like a douche...
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    Re: What do I need? (Headlights)
    i wanna know as well..
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    You need the blinker bulbs which i cant remember i can look at my extra set when i get home, and you need the high beam bulbs. I think they are either h10's or h7's. Weather or not they are the same from the a4 housings I am not sure. PM me if you can't figure it out they are common bulbs and Napa carried them for me.
    Secondly when i swapped my bi-xenon housings onto the car, the stock harness where to short. Luckly I had harness extension left over from my aftermarket headlights which give me another 6 inches.
    Edit : i just recalled they say on the housing themselfs what the bulbs are required.
    Last edited by vdubstreets; 06-11-2008 at 12:25 PM. Reason: i just recalled they say on the housing themselfs what the bulbs are required.
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    Bi-xenon Ecodes - You need H7 for the highs. D1S for the lows and 5GL ballasts. You also need a H6W (city light) bulb for each housing. Also euro corner bulb sockets.
    US S4 Housings don't use H6W (city light) and you need H10 for your highs. Same applies for lows (D1S and 5GL).
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Quote Originally Posted by vdubstreets View Post
    Quote Originally Posted by 02silverb6 View Post
    So I will need H10 bulbs for the highs and my D1S bulbs and ballasts should work!
    What brand/color would match my 6000K HIDs best?
    Aug 10 2007
    Toronto, Ontario
    what about single xenon ecodes?... what low beam does that take..? D1S as well, or H7?
    Feb 20 2007
    ct
    Your low beams are your HID's
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Can I use any part of my halogen harness to get the extra slack I need? If not, what can I do?
    Nov 20 2006
    ATL, GA
    Quote Originally Posted by Gondi Stylez View Post
    Im not sure as I have not upgraded my highs yet.
    Quote Originally Posted by EUROaleksey View Post
    Single xenon ecodes takes same low beam D1S
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Come to think of it couldn't I reuse my highs from my halogen housing along with the turning blinker?
    My D1S should take care of the bi-xenon part?!
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    Sorry to jack your thread, but do the single Xenon Ecodes have the city lights? And what mods would I need to make to run them? I just picked up a set off Ebay.de and I want to make sure I have all the parts.
    -Tim
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    yes single xenon ecodes take the h6w city light. you don't need to do anything, they work automatically via the harness
    Quote Originally Posted by sandspeed View Post
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Aug 10 2007
    Toronto, Ontario
    what the hell..... so the only way for someone to run 6000K or 8000K low beams is to have the stock halogen headlights? :(:(:(
    cause im pretty sure D1S only come in 4300K and i think i've seen 5000K on some website...... but thats so damn white :(... if people want blue-er, is there no other option but run the stock halogens? :(
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    I checked my headlights and on them it says:
    Highs: H6W
    Bi-Xenon bit: D1S
    Blinker: PY21W 3457
    Now everywhere I read it says the highs are H7? WTF?!
    EDIT: On the bottom of the housings it says - Halogen --> H7 EU/H10 USA
    Feb 20 2007
    ct
    your high is a h7,
    look at the h6w its prolly a city light
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    No city light so H6W is out!
    According to the housing my highs are H10s.
    I think I'll take my H7s out of my A4 lights and see if it works
    Oct 27 2007
    I can't speak for your NA spec lights but my single xenon ecodes use the following:
    - H6W city light
    - H7 high beam
    - D1S low beam
    - 7507 (PY21W) turn signal
