Results 1 to 30 of 30
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    So its gonna be a hot summer...
    Do you have any tricks to keep your interiors a little cool when parked?
    Do you do anything to keep the motor cool while driving?
    I'm contemplating one of those windshield visors to protect the dash from fading or cracking...I also have my windows tinted. What preventive measures have you taken to stay cool in the summer?
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Re: So its gonna be a hot summer...
    Quote Originally Posted by tike0rz View Post
    To be honest, tinting your windows doesn't do anything to keep your car cooler in the summer. The only thing that it does is stop the light from getting in, otherwise the UV rays and stuff like that can still get in.
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Senior Member Two Rings 01 S4's Avatar
    Jul 23 2007
    01 S4, 87 yj trail rig
    long island NY
    i use a windshield visor and close the cover to the sun roof if you know its not going to rain your could leave the sun roof popped up
    01 S4 -James-
    2001.5, 6 speed
    Darintake, 710N, Samco TTB
    GIAC X
    clutchmasters stage 4 and LW flywheel
    K04's ...there screaming
    piggies, ssac catback
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    Quote Originally Posted by alias747 View Post
    Ummm, wrong. Most tint companies design their tint to reflect UV rays. Tint does help reduce heat in the summer.
    Keep your sunroof on tilt when the car is parked, to let interior heat escape.
    B7 S4 Avant
    Apr 17 2007
    B8 A5
    The chick in your avatar is so hot, its hard to disagree with you!
    What I know is that in Florida, they charge significantly less to have your windows tinted because there is such a demand for it down there, due to the high temperatures.
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by BlackS4TT(Josh) View Post
    I bet that if you take 2 cars, one with tint, and one factory, and you park them in the sun all day and you go to enter them they will feel just about exactly the same temperature wise. When it's that hot outside anyway, the difference that tint is going to make is going to be negligible as to what you can feel. Sure on paper there might be a difference, but when you crack open your car door on a hot day your body doesn't care, it just says HOT either way! lol
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    ERs rule! Don't care about the interior, as long as I don't sacrifice much performance.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I've decided against wearing underwear
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Apr 05 2007
    Because that makes so much sense, high demand = lower prices. Freakin' Florida...
    Senior Member Three Rings Ber\/ani's Avatar
    Jun 03 2007
    Sacramento CA
    x2. the difference is minimal. i use a sun screen too.
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    im gonna go get me on of those windshield visors. i always try to park in the shade/cover.
    heres a short article on keeping the car cooler.
    http://www.coolnlite.com/CoolYourWheels.htm
    MSN Auto's article on how to keep your car cooler. but im sure most of you know the info.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Jan 11 2007
    Salt Lake City, Utah
    Tint does help in a couple of ways. It does block UV rays, so it protects the leather, dash, or whatever from sun damage. It also keeps the cool in longer, for example if you were to put 2 cars that are the same temp (cooler than ambient temperature) it will take longer for the car with the tint to heat up. If you park both cars in a hot parking lot all day however, they'll probably be the same temp inside. Tint also keeps you cooler when driving in that it reflects/absorbs some of the UV rays and radiant energy so you're not in direct sunlight.
    Active Member Four Rings
    Dec 11 2006
    Boston
    8% tint kept my car pretty fucking cool last summer.
    Stage 3+ RS6's
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    VAGCOM window roll down on remotes. I walk up, unlock unlock unlock(hold) window roll down, I get in.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Senior Member Three Rings Bee Five's Avatar
    Jun 06 2008
    Northern California
    While the ambient temperature might not be effected the surfaces inside your car will be much more bearable. Hot leather on bare skin is not comfortable for me so I have sun shades for all my cars. Every dealer has these available in the parts dept, usually around $35 and there sized according to your vehicle. I hate the "one size fits all" ones you can get at auto stores, their cheaply made and obviously do not fit your car. Get your fitted sun shade at the dealer, crack your sunroof and you'll be a happy camper.
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Just try and park your car in the shade... it makes a hugh difference.. and its better for your cars paint.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I have to say that I also disagree with you man. I've had a few cars that were tinted and I could tell a difference how they stayed cooler with the tint even in the sun. Granted it still gets hot in there, but could tell a difference between my car and my wifes car that didnt have tint. (No her car didnt have leather)
    Anyway, I have the black leather in my car and I have to say that even when its really hot out and in the sun, I havnt had much problem of the seats being unbearable to sit on even in shorts. (My current Audi doesnt have any tint except for what the factory has the windows at)
    To me the real thing we should be worried about is keeping the engine and turbo's cool as can be, thats whats more important
    This Tech article on audiworld is in my book a must do:
    http://www.audiworld.com/tech/eng.html
    Under heading:
    Low temp Thermo-Switch for S4 (B5) After-Run System
    It replaces the low temp thermo switch so it kicks in at lower temps instead of it waiting to be umbearably hot.
    One other thing I might do is take off all the plastic covers that make's the engine pretty. To me I dont care and I figure its something else that holds heat in... Maybe its not a big deal for these to stay on or also maybe taking them off it wont make that big of difference, but I figure it has got to help in some way.
    I'd also check to make sure your afterrun pump works. I need to do this on my audi.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jun 14 2007
    2000 S4
    Connecticut
    i have the cooler afterrun switch from ECS. did it with stage 3. it goes on ALL the time. which is good! spins the fans for about 10-15 mins after shutdown depending on how hot it got in there
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    It's hard to find shade by work. I have tint and also use a sun shade to help protect my ride from the sun. I may go to the Audi dealership and get a custom shade that fits right since the one I'm using right now doesn't fit exactly right. It works but it could fit better. I also crack the sunroof open to let the heat out.
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Get some cheapo windshield visors. They really do work. The car WILL be cooler when you get back in. The only pita is putting them in every time you park it.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Apr 17 2007
    B8 A5
    Quote Originally Posted by RolledMySTi View Post
    LOL
    Do what you want man, but I hate it when it gets sweaty down there...its like a plastic bag with 2 oranges in it!
    Apr 17 2007
    B8 A5
    Quote Originally Posted by gointoscott View Post
    Under heading:
    The afterrun pump is AWESOME. In cool weather it proves to be extremely proficient in lowering temps just by circulating the coolant and fanning a bit. It is such a cheap part, and quite easy to install, everyone should do it.
    I've also read up a bit on intercooler misters. Seems to lower temps by about 20% with just water. Just don't spray it when its freezing out, lol.
    Senior Member Three Rings GyzmoS4's Avatar
    Feb 07 2006
    Bronx, NY
    Quote Originally Posted by deb38 View Post
    The cop told me mine are 6% after putting the meter on my window lol. Between that and the remote window roll down, its never unbearable when i get in.
    J-Fonz tuned Stg 2+
    "Two wrongs don't make a right, but it makes us even."
    Registered Member Two Rings drewwynn's Avatar
    Jun 03 2008
    01.5 S4 Avant
    Michiana
    I just called my stealership. They quoted me 93.57 for the two parts needed for the thermo switch, what a rip. Anybody know where I can get them cheaper?
    Nogaro S4 Avant 6-Speed
    Stage 3-
    K04s, GIAC Stage 3- Tune, 5 Bar FPR, Samco TBB, 710ns
    Jun 03 2008
    01.5 S4 Avant
    Michiana
    just got them for 30 shipped from Autohaus AZ. By the sounds of thing this is a worthwhile upgrade to sit in the car and keep it cool. If nothing else it avoids you having to sit in the car after a spirited drive if you don't have a turbo timer.
    Stage 3-
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    Just buy a car cover. It'll take you literally one minute to put it on or take it off. You'll be amazed at how much cooler it is when you get in. And if you're worried about it being a hassle if you're just running simple errands, then realize that your car won't be parked long enough to retain that much heat. If it gives you peace of mind, crack your windows.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Veteran Member Three Rings DarkcydS4's Avatar
    Jun 13 2005
    e92 335xi FBO+Meth, 2014 BMW X3 M-Sport
    Madison, WI
    LOL
    LoL!
    Quote Originally Posted by ChriS4 View Post
    seriously? ....putting on and taking off a car cover everytime you park would be a huge PITA.
    Nov 09 2007
    Track Whore, CA
    Quote Originally Posted by DarkcydS4 View Post
    Uh.. I sorta meant it like "hey, when you go to work or over to your buddy's house for the day, put your car cover on. when you go buy milk, etc, leave it off because your car won't get hot enough to validate putting it on"
    '00 B5S4 - Sold
    Good USA
    Jun 13 2005
    Madison, WI
    haha my bad. Sounded like you meant every time you stop somewhere.
    Apr 17 2007
    B8 A5
    So we have:
    Car Cover
    Windshield Visor
    Auto down with remote
    Crack windows/sunroof
    Tint
    I think I'll go for the visor and cracking windows/sunroof while parking in normal parking lots, and use the car cover at night.
    That reminds me, I need to recharge my AC.
