Results 1 to 18 of 18
    Veteran Member Three Rings dmg312's Avatar
    Dec 08 2005
    OH-IO
    No ideas left. Turbo replaced and everything checked still not boosting.
    So a long story short. My second turbo blew at 52K miles. 2,000 miles over my warranty, and 3,000 over the turbo replacement warranty from the last one going.
    I have replaced the turbo with a new one. replaced a broken cracnkcase hose, and I'm still not getting all the boost requested. I've checked all the pipes, intercoolers(dual), and everything in between. The shop is saying the only thing they can think of is a bad wastegate.
    Has anyone ever heard of a bad wastegate on a new turbo? I can't name all the tests that have been done on the car, smoke and mist tests to find boost leaks, but what else can be done to find what's wrong?
    I consider myself pretty knowledgable aboout this stuff, but I am not near my car where it is being fixed. Happened far from home, so it's a very reputable VW Audi shop on the other side of town. going to see it later today anything Ishould look for?
    Thanks for the help.
    08 A3 2.0T Sprint Blue Sline.
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Re: No ideas left. Turbo replaced and everything checked still not boosting.
    Have you checked the DV?
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Dec 08 2005
    OH-IO
    Checked the DV, N75, Hoses, intercooler, gaskets, everything I can think of.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    you can test the wastegate itself you know. You just need to attach a hose and a finely adjusted air compressor delivering whatever boost you want and see if it opens. Probably easier to take it off the car to do this. This is commonly done to snych turbos for bi-turbo setups.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Registered Member Two Rings 1.8G's Avatar
    Jul 09 2005
    99 1.8t, stage III
    Sacramento
    had the same experience... turned out that the cat was bad, and was restricting exhaust flow so i could only produce ~3 psi... do you have any odd rattles at idle?
    4 turbos, 2 clutches, 1 addiction and 0 money.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    ^^maybe an exhaust leak or cracked exhaust manifold? you may not have enough backpressure to get the required boost.
    USP CLUB MEMBER #34
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    You should do a boost leak test:
    http://forums.audiworld.com/a4/msgs/1659806.phtml
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Quote Originally Posted by Splattj View Post
    Did you actually read the OP?
    Quote Originally Posted by dmg312 View Post
    That's a brutal situation, GL!
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Buncha motorcycles
    Memphis, TN
    i had a similar problem (i leak tested, couldnt find anything).. turned out it was a faulty APR R1 DV... do you think one of the plastic end caps on the intercooler could be cracked and only opening up under boost? i know u said u checked them, but...
    APR Stage 2/AWE Intake
    Nov 13 2007
    Gaithersburg, MD
    Quote Originally Posted by Tactic12 View Post
    I did. Smoke and mist tests while the car is running can't cover all of the system and a visual inspection of all the pipes doesn't rule out a boost leak.
    If, when pressurized, there's no indication of a boost leak, the only two components left are the wastegate and bypass valve. I've had four turbocharged cars and I've been through everything. Cracked flapper valves on the internal wastegate flapper, clogged cat (which ended up failing spectacularly!), leaky BOV, broken endtank, you name it. For $15 worth of home depot parts, it's worth pressurizing the system.
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Did the problems begin right after you went Revo?
    Not sure if it'll help, but i just couldn not get the proper boost after going K04 (GIAC, stg2+), checked everything 10 times over, tunning shop kept saying bad N75, or wastegate, tested wastegate - no problems replaced N75 - still same. So finaly i ended up getting rid of (brand new) N75 altogether and going turbosmart MBC - that did it. Its been perfect boost ever since.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    I doubt it's a manifold issue cuz I have recently had a leak between manifold/turbo. The car sounded like a Harley but the car was still able to reach full boost with Revo stg 2 (26 psi). If you checked all the hardware/mechanical parts I would look to the software or maybe it's still an N75 issue like alexa4 said.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Dec 08 2005
    OH-IO
    I'm starting to think it's more likely a bad wastegate. How do you check that?
    Obviously I'm paying to have the turbo removed again, but I want to check that befor eI do anythting else.
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Take out your primary O2 and if you boost significantly more or at all then your cat is bad.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    if it comes down to it, call up a solid local audi shop and usually they will cover the cost of a tow if you want them to finish the work. i almost had this done with a clutch job, but in the end it was such a large repair i didn't want to transport my transmission while outside of my car...
    good luck
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Nov 13 2007
    Gaithersburg, MD
    Wastegate failures usually manifest themselves by overboosting. If the diaphragm fails, it won't actuate and the turbo will make maximum boost. If the actuator arm becomes disconnected from the flapper valve, or if the flapper doesn't seat properly, you will lose boost. In your case, since you're not getting enough boost and you have a new turbo, you most likely have a case of excessive backpressure, a bad boost control selenoid (N75), a boost leak, or a software issue.
    How much boost are you getting vs. expecting?
    Dec 08 2005
    OH-IO
    The issue is this. (taken from the tech account as I have yet to drive it. Went to yesterday but got stuck in 45 minutes of traffic before I even left my side of town.) Whne the accelerator is hit, boost comes on, when the car requests a spike the turbo kind of builds a little, flutters, and drops down some and holds steady. I'm not sure of the numbers, but instead of producing 1+ power it is more like stock.
    To me it sounds like thte wastegate is bad, and cannot hold boost. As boost builds, and there is a spike either a bad seal, or bad spring lets it open and excess boost tis just passed by.
    I was told the N75 was checked. How much is it tot rplace that, and how easy. Might be a good step before I take the plunge and have the old wastegate put on the new turbo.
    Feb 23 2004
    Stow, OH
    A new N75 is $100 at ECS. I have a new one I don't need that I can let you have for much less. PM me if interested.
    It's not too difficult to replace, but you need to work in a slightly tight area to get everything connected. Take your time, and you can have it swapped out in under an hour.
    USP CLUB MEMBER #34
