Results 1 to 15 of 15
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    DIY How to check Cam Lobe Wear?
    I really do not want to ask but i have searched EVERYWHERE and can't find the DIY on how to check for the cam wear and i know its here somewhere......... Anybody that can help me that would be great!!!! I have 90,000 miles on my 05.5 so i need to change the TB and figured id check the CAM as well...
    PS: I know you have to change the TB at 75k but atleast it was all highway miles....
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: DIY How to check Cam Lobe Wear?
    you have to take out the fuel pump, and visually inspect the cup that touches the lobe, and the lobe itself. My cup was bad while my lobe was ok.
    To check the lobe have someone spin the motor manually and touch the lobe and check for irregularities.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Jan 27 2007
    NC
    Thanks HID for the info it will help quite a bit.
    If i do have wear on the lobe is anyone using these for an upgrade? Would they be good choice? Also what kind of HP increase did ya see?
    http://www.kmdtuning.com/store/index...&productId=996
    thanks,
    vizi
    Quote Originally Posted by HID View Post
    Veteran Member Three Rings A4RingPimp's Avatar
    May 24 2008
    DG '06 A4/ '08 Land Rover LR2
    On a peninsula
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by viziers View Post
    vizi
    where you at in NC? and damn 90k, where do you drive!!! thats double my mileage and I have a 05.5 also.
    Jan 27 2007
    NC
    Quote Originally Posted by nsmith12 View Post
    nsmith12,
    I live in Snow Camp Nc and i drive to Winston Salem three times a week and four times every other week for a total of 165mi a day.
    PS: JB from Perfcafe is putting together and timming kit for our cars and should be out in the near future....I hope to be the first to get the kit...
    vizi
    Nov 05 2007
    Auburn, AL
    Nov 12 2007
    Grand Junction, CO
    Hey Mike,
    If there is Cam Lobe Wear, would that cause RPM fluctuations in the mid RPM range while accelerating (with APR Software)?
    Jan 27 2007
    NC
    Thank you A4RingPimp and Mike from APR!!
    That info will help out a bunch!!
    vizi
    Jan 27 2007
    NC
    Hey Mike,
    How do you think this Garrett GT2876R would work on a 6mt FWD a4?
    http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
    PS: I'm new to the turbo scene so if it is way wrong please help a person out.. Thanks... Oh and i know the turbo and Ex. Manifold are a one piece im gonna improvise on the turbo and manifold assembly.
    PSS: Also ill have the supporting mods to with it as well obviously...
    vizi
    Oct 14 2006
    MK6 Jetta
    South,FL
    That would be lots of fun, but I would get a new cam for that. Plus prepare for wheel spin & hop from hell you need to get motor mounts and a tranny mount to combat this ( know from experience ).
    Ps. You need a B7 specific turbo kit.
    -EI AL CAI.
    -Driver Mod.
    Jan 27 2007
    NC
    HID,
    Yea i know i need a specific B7 kit but im pretty sure it does not exist yet so i was going to i guess experiment a little but obviously will need help and advice along the way. Thats why i had asked about the GT Turbo. lol
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    I think vast has the only BT kit out so far, wait till the end of summer and there will be more options.
    -Kris
    Oct 14 2006
    MK6 Jetta
    South,FL
    HID,
    Well, if you are going big turbo forget about the Gt28, Gt30 is the way to go along with internals.
    -EI AL CAI.
    -Driver Mod.
    Jan 27 2007
    NC
    That would be nice but i still need it to be a DD.
    vizi
