Results 1 to 4 of 4
    Established Member Two Rings themig90's Avatar
    Feb 12 2008
    2006 A4 2007 A8
    West Palm Beach, Fl
    Changing oil & Filter
    Not going to the Stealership, first oil change after 50k maintenance program, what oil and oil filter do you guys recomend?
    thanks in advanced
    Senior Member Two Rings ABL2point0T's Avatar
    Nov 09 2006
    Charlotte, NC
    Re: Changing oil & Filter
    Get the Audi filter from the dealer, or online. I would say you are safe to use any synthetic that is up to the VW/Audi specs. There is a list on the Audi website, you can just choose your favorite brand. I may have the PDF file saved on my laptop at home, if someone else doesn't post, I will try tonight.
    2006 A4 2.0T Titanium 6 Spd Manual (Sold)
    2008 335i 6 Speed Manual
    PS3 Username: Wolfpack1
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    I change the oil in between service intervals with Motul 300V. As soon as the car comes out of the dealer I flush the Mobil stuff out and put Motul again.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Mar 19 2008
    northside SD
    i use mobil 1 oil and stock oil filter from dealer. works perfect for me.
