Results 1 to 4 of 4
    Nov 04 2005
    05 USP (The last of the best)
    City of Sin
    Question USP To S4 Grille Question
    I have a 05 USP and want to change out the stock upper and lower grilles it came with to the upper and lower OEM S4 Blackout grilles.
    After searching I assume the OEM S4 upper grille with fit with no issues. Correct?
    As for the lower grille, I do not have the stock USP grille anymore due to a minor accident. After searching I got the impression that you need that USP lower grille trim for the S4 grill to fit inside of it? Or will the S4 grille work the same as the upper?
    Just wanted to verify so I can order both of these and have a shop install them and make it work with minor fabrication. TIA and I appreciate all help regarding this issue.
    Brian
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    Re: USP To S4 Grille Question
    Upper will fit no problem.
    Lower needs to be trimmed to fit. I don't believe you need the USP lower trim frame.
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Easier thing to do is to get the blackout lower USP grill. ECS sells it.
    USP CLUB MEMBER #34
    Senior Member Two Rings JonnyQ's Avatar
    2003 A4 3.0 quattro 6spd
    Long Island, NY
    upper fits no modification.
    lower needs to be trimmed to fit. Its possible to do it without USP trim, but you'll have to rig up some sort of trim of your own to make it look right. using USP trim would be much easier.
