Results 1 to 4 of 4
    Nov 03 2007
    03 A4 1.8T, 02 VW 337
    Harrisburg, PA
    Upgrading Symphony radio....?
    Hi all. I am looking to upgrade my 2003 Symphony II radio to one out of a 2004. They look exactly the same except for the button that says SAT on the new one.
    My question is... What to I need to make the SAT function work with the new one. This is the whole reason I bought the unit, to get the ugly Sirius tuner off my dash.
    I have the radio, and I see I can plug my old SAT antenna in to the rear of it possibly. I imagine i need the tuner thing that goes in the trunk? How does this hook up? To the Changer plug?
    TIA
    Aug 26 2005
    Re: Upgrading Symphony radio....?
    You need the SAT receiver/tuner module. you can mount it under the dash, the sat antenna wire would need to be run up to the dash, and plugs into the sat receiver/tuner. You will need the harness between the HU and the receiver/tuner fabricated, I recommend "TeddyBGame" on the A6 Forum, or on NavPlus.us The wiring to the receiver/tuner is added to the existing ISO harness connectors, or an insert adapter harness can be made for Plug and Play install.
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    If you don't have a roof antenna then your car's not hard-wired already. But getting it wired up isn't so bad. See my DIY in the Telematics forum. It'll take some work and some eBaying but it can be done.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    there's about 3 posts on this per week. search
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
