Results 1 to 19 of 19
    Apr 22 2007
    Riverbank, Ca
    Anyone know how many lateral G's there makin?
    Just curious if anyone knew how many lateral G's they are making, street tire or not.
    Post your suspension setup, tire, weight reductions made, and estimate HP.
    Andrew
    Veteran Member Four Rings Rhynolite's Avatar
    Sep 12 2007
    A
    Re: Anyone know how many lateral G's there makin?
    I have a nifty gadget in my car that reads G's forward/backwards and left/right.
    Most I've pulled was 1.3 sideways G's in a corner.
    FK Coils, Kumho Ecstas ASX, zero weight reduction, ~210hp.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Peak G is totally different than the sustained G magazines report from skidpad testing. A stock minivan can hit way over 1 g in an emergency maneuver.
    Jim
    I Do Werk.
    Apr 22 2007
    Riverbank, Ca
    1.3 Eh?
    Your nifty gadget is wrong... lol. What are you using?
    Stock is under .90, and I think our cars (were both similarly setup) should be close to .95 or .98, (Very few street cars can go over 1G on street tires). At the last autox I was in the tarmac was very sticky and my tires where nice and hot and grippy, I have a sneaking suspicion that I surpassed 1G that day, but I have no way of knowing until I go back out with my Gtech.
    Mar 09 2004
    nw michigan.
    Vid of a stock BMW 320si hitting 1.10 g.
    http://www.youtube.com/watch?v=cEPPu67Da3Y
    Again, peak or momentary g is a lot different than maintaining that average for a full revolution of a skidpad. Take it from someone that has run around tire rack's skidpad until almost puking. My old 94 Jetta VR6 on Azenis hit 1 g average. My Avant probably did a bit better with corner balanced coilovers, H-Sport bars, and r-comp tires but there was no meter in the car. I'd bet my new suspension setup (Shine Racing custom valved Bilsteins, stock sport front bar, H-Sport rear bar) does even better since there will be less body roll and better balance.
    Jim
    I Do Werk.
    Oct 06 2004
    Minnesota
    G-TECH PRO!!!!!!!!!!!!! lol
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Quote Originally Posted by A4Rob View Post
    "First they tested it. Now they test with it" GAY
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 04 2005
    14 MkVI, 11 Sienna AWD
    530, California
    Quote Originally Posted by onemoremile View Post
    To bad 5th gear isn't broadcast here anymore, I miss it, rivals TopGear in my mind.
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    Mar 09 2004
    nw michigan.
    Check out finalgear.com.
    Jim
    I Do Werk.
    Jan 19 2008
    Quote Originally Posted by Nor_Cal_Driver View Post
    Fifth Gear is good for content but they can't match Top Gear's comedy.
    Sep 12 2007
    A
    Quote Originally Posted by andyrew View Post
    1.3 Eh?
    I can most likely get a screenshot of the corner and the exact moment with the readouts of when I was hitting 1.3G. That was max of course, I was probably hovering around 1.1-1.2 for most of it until the center.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    lol, that isnt just any BMW. the car is a specialized touring car. Granted it is stock but not a car you can go out and buy easily.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by gotaudi View Post
    I'll bet an M3 does better. So will a lot of performance cars. Others may do worse. The point was that it is achievable on street tires in a stock car.
    With my tires and suspension I should be able to do at least that well. Of course, my tires have a 160 treadwear and are very grippy but they are still a long way from real r-comps. Hoosier Rs should do 1.2 or better on our cars with proper suspension setup and the As will do even better.
    Jim
    I Do Werk.
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Good point
    Mods:
    Senior Member Three Rings Insomniac's Avatar
    Jun 03 2008
    Hershey
    I'm fairly certain you can use a Nintendo Wii remote to measure g forces. I'll dig up the link. I got a Wii so I need to test this out.
    Here's the info on using the remote: http://forums.vwvortex.com/zerothread?id=3362586
    Why not use the wiimote's built in 3-axis accelerometers to measue g-forces, acceleration and even calculate my own 0-60mph times!
    free earl
    Apr 22 2007
    Riverbank, Ca
    Quote Originally Posted by Rhynolite View Post
    It certainly seems like a lot to me. I know my Gtech isnt extremely accurate (which is why im getting a RR one..)...
    Was it full on camber corner? because that will greatly increase your possible grip.
    That WI remote is awesome... but I doubt its very accurate..
    Jun 03 2008
    Hershey
    Not highly accurate because it rounds the numbers to two decimal places.. But I'm gonna have to try it out some weekend.
    free earl
    Sep 12 2007
    A
    Yeah it probably was like ~.1 off, but it definitely felt like it was up there.
    I'll upload the screenshot hopefully tonight.
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Do you mean a super elevated curve? that doesn't increase the physical grip it just moves the cars center of gravity.
    Mods:
