    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    Help me with some brake calculations plz
    So, there's a lot of drama regarding these brake calipers I recently bought ...
    http://www.audizine.com/forum/showthread.php?p=2522000
    http://www.audizine.com/forum/showthread.php?t=213343
    if you feel like reading it ... but cliffnotes: they are custom made st40 calipers for a different car (not audis) but st40 blanks are all the same, just these have 32mm and 36mm piston sizes, instead of 32mm and 38mm.
    ill eventually need to machine the caliper mounting bracket, but ill cross that bridge when i get there (and when i have access to a 5axis cnc machine)
    can someone just chime in on these calculations? also does anyone know what the calculation for finding brake bias? assuming everything except piston sizes stays constant.
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Help me with some brake calculations plz
    My brain hurts just looking at that.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Nov 16 2006
    Boston
    its a simple area calculation ...
    though i just realized my values for radius is actually the diameter ... so i need to re-run the #s .....
    but is that right? i feel like i should be using pi*(r2-r1)^2 because that's the actual contact area ...
    1999 Black A4 Avant
    Apr 05 2007
    wouldn't pressure play as much, if not more of a factor than area?
    Nov 16 2006
    Boston
    pressure matters too obviously ... the formula for force is Force = Pressure*Area ... but the pressure is pretty much given from the master cylinder. the area is the piston area ... so if pressure stays constant, and the area increases, the braking force increases
    1999 Black A4 Avant
