Results 1 to 13 of 13
    Senior Member Three Rings gunxit's Avatar
    Sep 16 2006
    Audi S4
    Angeles Crest 818
    Calipers repainted in LA area?
    My ECS Stage 4's need repainting badly. Any1 know any shops around LA area?
    I'd like to keep the lettering on the calipers and prefer paint over powdercoat.
    TIA!
    Sep 16 2006
    Audi S4
    Angeles Crest 818
    Re: Calipers repainted in LA area?
    Any1?
    I need these repainted asap
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    I know of a place in the OC but not sure about LA.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Sep 16 2006
    Audi S4
    Angeles Crest 818
    At this point, I'll consider any options.
    DUH! an Audi
    los angeles, CA
    try a body shop or powdercoating place, i told you already!
    Sep 16 2006
    Audi S4
    Angeles Crest 818
    Quote Originally Posted by Quattro View Post
    Since powdercoating is done at very high temperatures (300F +) I decided to stay away from it and save myself from removing or ruining the pistons.
    Ended up going to DTM Autobody in El Monte, CA (Thanks Peter!).
    Senior Member Two Rings BadLuckB7's Avatar
    May 04 2005
    2005 Porsche Carrera 4S, 2016 Audi A5
    Call Platinum Motorsports on Melrose. i saw them paint a set of mercedes calipers to match the Brembo red, they came out awsome...
    Current:
    2016 Mythos Black Audi A5 2.0T Quattro Coupe
    Previous:
    2007 Brilliant Black Audi A4 2.0T Quattro, S-Line 6MT
    2001 A4 1.8T Silver/Black,5spd
    (197whp,247wtq) on K03 w/ APR stgII
    - Gone but not forgotten.
    Established Member Two Rings cloaked's Avatar
    Jun 11 2008
    West Hollywood
    Quote Originally Posted by BadLuckB7 View Post
    Where is this place Melrose, the general area please.
    Quote Originally Posted by gunxit View Post
    What was the cost? did you have all of the calipers painted, I've seen some places that charge so much for painting that you're better off just buying a new painted set of calipers.
    Veteran Member Four Rings mioStile's Avatar
    Sep 25 2006
    LA AUTOSPORT in west L.A. on Cotner
    la-autosport.com
    Current Iggnshn: 2007 4.2L 6 speed quattro S4. Neuspeed catback. 20x8.5/20x9.5 BBS RSGT. PSS9. USC license plate. always my work in progress.[/FONT]
    AMA
    Together we can all defeat 2.0T and 2.7T crime
    Ya, I'm that guy...
    Sep 16 2006
    Audi S4
    Angeles Crest 818
    Quote Originally Posted by cloaked View Post
    PLATINUM MOTORSPORTS
    7327 Melrose Ave
    Los Angeles, CA
    (323) 935-9222
    If you're coming from the 10FWY. Get off on La Brea, go down to Melrose and make a left. Keep going on Melrose and you'll see it on your right side. You can't miss it. Bunch of high end cars.
    $250 to remove both calipers, sand them down. High temp primer, nice coat of Brembo red, emblem and thick clear coat over it.
    I was desperate and went for it. I'm getting it done at DTM Autobody in El Monte, CA.
    We'll see how things turn out.
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Sep 16 2006
    Audi S4
    Angeles Crest 818
    Quote Originally Posted by belinko View Post
    GMG is always good. But too far for me.
    Dec 06 2007
    DIY it it's not hard!
    -Kirk
    BetaAlphaTau Member #58
