We have just received in a 1997 A4 1.8T Quattro with a 5 speed manual that we are parting out. The car was not in an accident of any kind, it was simply retired by the owner because of high mileage (220,XXX on the chassis). However, it was full of mods, and had a lot of maintenance done in the past two years (the owner put 40-50k highway miles a year on it), including a full engine rebuild done 45k miles ago! The car also has a Southbend Stg 2 clutch with 25k miles on it, in great condition.
We've thoroughly tested everything coming off the car for good appearance, functionality, and overall condition. Anything questionable gets thrown in the trash, we strive to only sell good used parts in good faith. We warranty every single item we sell to be non-DOA! If you receive something that is damaged or defective, we will work with you to make it right, be it an exchange or a full refund including shipping!
We have parted out over 15 B5 A4s from 1996s to 2001 models. We have nearly everything imaginable in stock for them, if you don't see something listed here for your car shoot us an email at [email protected] and we can check our availability on it. Please include the year, model, and engine, as well as your zip/postal code if requesting a shipping quote. Sam, Brant, or Chase will get back to you as soon as we can!
To browse some of our available parts inventory, check out our eBay store here: http://stores.ebay.com/A-PAutoSpecialties-LLC
Email us as well if you would like pictures of anything listed here (or anything else for that matter).
We ship worldwide, nothing is too big nor too small to ship anywhere!
A&P has been parting out Audis for over a year now, formerly under the username MPLSChase. You can check out his previous buyer feedback here: http://www.audizine.com/forum/showthread.php?t=130524
A&P Auto Specialties opened in an 8400sqft shop in Independence, MN, just 15 minutes west of the Minneapolis metropolitan area. We've continued as a business what Chase started as a hobby in his garage, that is, an exclusively Audi-only used parts warehouse, full service shop, and aftermarket parts vendor. To learn more about what we have to offer, check out our website at www.ap-specialties.com. We look forward to helping our customers, and value our relationship with them and the broader community!
To view feedback on us from our Audizine customers, please click here: http://www.audizine.com/forum/showthread.php?t=198448. If you're a new buyer of ours, please let us know how we're doing there as well.
Warranty
Used Parts: A&P Auto Specialties, LLC Guarantees no DOA. If you have received a wrong item or defective part, we will gladly replace it, if possible, or return your money (including shipping) in full! A&P Auto Specialties, LLC MUST be notified within 7 days of receipt of the part that there is a problem. In the event of shipping damage, all original packaging MUST be kept and pictures taking and emailed to A&P Auto Specialties, LLC within 7 days of receipt of the part, if there is a problem.
Your satisfaction is our priority!
Anywho, enough of that, on to the parts!
Engine
Complete 1.8T Engine w/Wiring Harness (Code "AEB") - $1600 (45,XXX Miles on a full rebuild! 185-180-180-185 Dry/215-200-215-215 Wet compression numbers!)
Transmission - $400
ECU (557P ECU, stock!) - $150
Turbo K03 - (Minimal Shaft Play - GOOD!) - $150
Intercooler Side Mount - $50
Intake Manifold Cover - $40
Timing Belt Covers - $25/Ea
Throttle Body - $150
Intake Manifold - $80
Exhaust Manifold - $50
MAF w/Sensor - $80
Power Output Stage (POS) - $60
Coil Packs - $15/Ea
Rail w/Injectors - $15
Injectors (stock) - $5/Ea
Engine Mounts - $40/Ea
A/C Compressor - $50
A/C Condenser - $50
Radiator - $50
Radiator Core Support w/o Fans - $150
Radiator Cooling Fan (Electric) - $60
Viscous Fan Clutch (w/o Fan) - $40
Viscous Fan Wheel - $20
Starter - $50
Alternator - $50
Oil Cooler - $30
Power Steering Cooler - $30
Power Steering Pump - $50
Differential - $100
O2 Sensors - $40/Ea
Coolant Reservoir w/sender - $30
Wiper Motor - $30
Wiper Linkage - $50
Washer Spray Nozzles (Main) - $30/Both
Washer Spray Nozzles (Headlight) - $40/Ea
Washer Fluid Reservoir - $40
Washer Fluid Pump (Main) - $40
Washer Fluid Pump (Head Light) - $40
Shift Linkage (5sp) - $40
Air Filter Box - $40
Air Filter Box Ducts - $20/Ea
Fuel Pump - $80
Fuel Sending Unit - $30
Drive Shaft w/Carrier Bearing - $100
Southbend Stg. 2 Clutch w/ 25k - $250
Stock Dual-Mass Flywheel - $50
Brakes/Suspension
Intrax Coilovers - Blown shocks, in 'used' condition, sold As-Is - $100
ABS Module - $100
ABS Speed Sensors $40/Ea
Brake Calipers w/Carriers - $40/EA
Brake Booster - $40
Brake Master Cylinder - $40
Brake Fluid Reservoir - $25
Front Rotors - $15/Ea
Rear Rotors - $15/Ea
Tie Rod Assy- $40/Ea
Control Arms $40/Ea
Differential - $100
Axles Rear - $50/Ea
Axles Front - $50/Ea
Rear Knuckles/Knee Assy w/Hubs - $50/Ea
Exterior/Body/Lighting
Headlights (two piece DOTers) - $75/Ea
Corner Markers - $30/Ea
Driver's side Mirror Housing (No Glass) - $50
Passenger's side Mirror Housing (No Glass) - $50
Trunk - $150
Grill (Badged) - $50
Bumper Grille (Center) - $30
Window Frame Assy With Windows (no Motor) - $75/Ea
Side Windows (Glass Only) - $50/Ea
Window Frame Assy W/O Windows (no Motor) - $25/Ea
[/b]Hood - Great shape, only minor rock chips - $150
Front Fenders - Oval badge, square marker - $100/Ea [/b]
Door DS Front - $100
Door DS Rear - $100
Door PS Front - $100
Door PS Rear - $100
Exterior Door Handles - $40/Ea
Fender Liners - $30/Ea
Moon Roof Assy Complete (Glass) - $150
Rear Bumper Assy - $150
Rear Bumper Shocks - $40/Ea
Front Bumper Assy - Was modified for FMIC piping, crack at bottom of side grille on driver's side - $100
Front Bumper Shocks - $25/Ea
Door Weather Stripping all four doors - $20/Ea
Rear Tail Light (Old style, but have '98.5-'99 lights available!) - $60/Ea
Tail Light Bulb Holders (old style on this car, but have updated ones available for $30/Ea) - $20/Ea
Interior/Electrical/Stereo
4-Spoke Standard Steering Wheel (We have '98.5 sport wheels available! - $175 with airbag!) - $50
Instrument Cluster w/o info display - $60
Beltline, w/o Radio and shifter Surround - $125
Radio Surround (Black) - $40
Shifter Surround (Black) - $30
Climate Control - $100
Central Locking Pump - $100 Sold
Cruise Control Module - $60
Airbag Module - $80
ABS Computer - $100
Shifter Knob Black Leather - "Early Sport" - $30
Shifter Boot Black Leather - $25
Radio - Non-Bose Delta with Code - $75
Non-Bose Speakers - $40/ea
Pillar Trims A,B,C - $30/ea
Headliner with Sunroof cut-out - $100
Dash (Light Grey) - $100
Passenger Air Bag - $100
Sunroof Switch Panel w/Lights (Good Condition) - $60
Front Driver's Seat (Grey Leatherette) - $150
Front Passenger Seat (Grey Leatherette) - $100
Rear Seat - $100
Center Console Bronze Grey - $80
E-Brake Handle - $30
Door Pulls Black (no switches) Good Condition! - $40/Ea
Sun Visors - $20/Ea
Column Switches/Stalks $30/ea
Window Switches - $10/Ea
Seat Heater Switches - $15/Ea
Interior Door Handles Black/Silver Good Condition - $30/Ea
Sunroof Motor - $75
Window Motors - $40/Ea
Window Regulators - $40/Ea
Kick Panels - $20/Ea
Heater Box Complete w/Heater Core, A/C Evaporator and Fan Motor - $100
Blower Motor Fan Assy - $60
Rear Window Deck w/3rd Brake Light - $50
Tilt Steering Assy. w/ignition and Key - $60
Center Heater Vents (3 total, sold separately) - $15/Ea
Side Vents - $15/Ea
Rear Vents - $15/Ea
Overhead Grab Handles - $10
Front Seat Belts - $50/Ea
Rear Seat Belts - $25/Ea
Interior Floor/Door Trim (from Front to Back) - $50
Exterior Black Door Sills - $50/Ea
Center Rear View Mirror (Windshield) - $40
Prices do not include shipping, domestic shipping is handled through UPS, and international shipping goes through USPS. Large domestic items are sent through Greyhound's shipping service or through freight, contact us to arrange.
We pride ourselves on providing you with a fair and honest shipping price, contact us with your postal code for a quote!
Again, if interested, contact us to [email protected], and we'll be happy to work with you.
Sam
Team A&P Parts Sales
