Originally Posted by
TheReflex79
No buttons on the steering wheel for a 98.5....the dealership is going the easily route by telling me the whole shifter needs to be replaced....but find it hard to believe. Using the shifter, in tip mode, if I want to up-shift, I have to tap it 2-4 times to get it to shift. The only thing that read is that there may be magnets that need to be adjusted. But the dealership simply want to replace the whole shifter, and take alot of cash I'm currently lacking! lol
Use a vagcom and see what is really happening!
Mine was doing the same thing, i found the magnets were misadjusted and i could just lightly bump it up a hair and it would upshift and work that way.
The problem i had is it would shift once, then i'd have to do it 3-4 times again to get it to respond. The actual cause was that after i pushed it up the 1st time the switch/tcm saw it as i was still just holding it UP so it didn't see that I had released it. I've learned to work around it and actually like it a lot better, try a shorter push rather than all the way to the top of the shift gate if that makes sense.
-richard
