Results 1 to 2 of 2
    Registered Member Two Rings AudiloverS4's Avatar
    Feb 21 2007
    Santa Barbara
    Surface scratch removal
    Seems someone brushed up against my car with a keychain/laptop bag/backpack/etc, resulting in a scratch about 10inches in length. Just a mild paint scratch, I only noticed the scratch after cleaning the car. What is the best method for removing such a scratch?
    Thanks in advance.
    '04 B6 S4 Black on Alcantra
    Milltek DP's| Milltek resonated catback| V1 hardwired | Hoen Xenonmatch fogs | Pioneer AVIC-D3 | HRE C21
    Veteran Member Three Rings Twista616's Avatar
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    Re: Surface scratch removal
    Quote Originally Posted by AudiloverS4 View Post
    Thanks in advance.
    First you'll need to determine if the scratch can be removed first. Take your index finger, or any finger at that...run your finger nail across the scratch. If your finger nail catches on the scratch, it more than likely will not be able to be removed by polishing. There are many variables that come into play to determine if the scratch can be removed or not. If it cant be removed, and can be diminished drastically by polishing...
    Depending on how much clear coat is present, it may be wetsanded, then polished out, but there is a risk of burning through the paint.
    Post some pictures, that will help us determine, yay or nay!
    "I'm right 60% of the time, all the time!"
    2005 A4 QT-SOLD // 2006 A4 QT-SOLD
    '14 SQ5 | Ibis White | 21" Stockies | More goodies in the works
    Insta: @imgarretthess Tweetness: @imgarretthess
