Originally Posted by
ekaufman
nsmith12 - so you even rubbed on 19x8.5 with 245/35/18s? Im surprised. Were you lowered on the Stasis kit in your signature. If I go with 18" wheels on the stock sport suspension, I think that size would work.
No the problem wasn't rubbing at all, the problem was the tire was actually too wide (245) for the 8.5" tire. It hung over the wheel at the correct PSI for the tire and it actually hurt performance. I now have a 19x8.5 with 235/35/19 with and a 25.25" ride height on front and rear with my Stasis Coils and it doesn't rub at all.
So to reintorate the problem isn't that you will rub (you might), the problem is that you need the correct size tire because in this case bigger/wider isn't always better and especially in this case. PM me if you have any more questions.
And visually it looked bad, it poked out and hurt the look of the wheel
